Adding brake lights with 4-wire turn signals - Part 1
I have a solution to our weak brake light ... add more brake lights
![]() The idea is to replace our stock turn signals with a four wire version that has an integrated running light, turn signal and brake light. The outside half of the light is a flashing yellow turn signal. The inside is a red running light. When the brakes are applied, the red becomes brighter. The yellow continues to flash while the brakes are applied. In Part 1, I install the new turn signals and connect the turn signal and ground wires. Part 2 ... connecting the running light and brake light ... will have to wait until my 3.5 mm bullet connectors arrive. To do the hard part (signal installation), all you need is the 4-wire turn signal. It comes with a clear, smoke or red lens, and a black or chrome housing. But functionally they are all identical. I got the clear ones with black housing at this link ... http://www.ebay.com/itm/162085844414Or from the sellers page (need_for_parts) if this listing expires ... http://www.ebay.com/sch/need_for_par...1&_ipg=&_from=Or search for 'Motorcycle Integrated LED Turn Signals & Tail Light' in ebay. The third pic compares the new signal to stock. They are nearly identical. The 4-wire module is slightly shorter, but has more LEDs inside. Its stem is also shorter and not as flexible. The wires terminate in 3.5mm bullet connectors just like our stock turn signals ![]() Wire colors:
Before you start working, test the new turn signals to make sure each light works. You can usually use a 9 volt battery. Or remove the bikes electrical panel and test them using the constant power brown + and green ground license plate wires. Plug in black to green and then touch yellow, red and white to brown one at a time.
Red 5 standing by! 2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery 2014 Ural Patrol Last edited by detours; 06-27-2016 at 03:28 AM. |
Step 1: Remove the tail end components
Although you can see the turn signal mounts, I couldn't find a way to unbolt them without removing the tail assembly.
First, remove the easy parts. I forgot to take pics of this part, but it's pretty simple.
Red 5 standing by! 2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery 2014 Ural Patrol Last edited by detours; 05-31-2016 at 11:02 AM. |
Step 2: Unbolt the tail assembly
Now remove the main bolts of the tail assembly and the rear body panels.
Red 5 standing by! 2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery 2014 Ural Patrol Last edited by detours; 05-31-2016 at 01:43 AM. |
Step 3: Finish loosening the tail assembly
After these steps, the tail assembly will be loose enough to reveal the turn signal bolts.
Note: If the tail assembly still doesn't move, look for any bolts I may have missed.
Red 5 standing by! 2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery 2014 Ural Patrol Last edited by detours; 05-31-2016 at 02:42 AM. |
Step 4: Unbolt the electrical panel cover
The electrical panel cover is attached with four bolts. Remove the bolts and lift out the tray. (I actually did this first, but I didn't want to edit my previous posts.)
Step 5: Expose the tail light wiring harness
Turn the key off to do the electrical work in this part. 12 volts isn't enough to hurt you (you can't even feel it), but you could still short out something by mistake. Many recommend disconnecting the battery.
The tail lights and turn signals are located in a water resistant rubber boot at the rear of the electrical panel.
The turn signals use 3.5mm bullet connectors. These are the same size as the bullet connectors on the 4-wire turn signals, so they will plug right in and will be usable immediately. However, the tail and brake lights use a unique 3-wire harness and connector. This will require some splicing to wire up, which I will cover in Part 2 next week.
Red 5 standing by! 2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery 2014 Ural Patrol Last edited by detours; 06-07-2016 at 09:21 AM. |
Step 6: Remove the stock turn signal (one at a time)
Finally, it's time to unbolt the left rear turn signal.
Important: Unbolt one side at a time, so you can keep track of which side uses which wires.
Step 7: Install the 4-wire turn signal (one at a time)
Remember to install the turn signals one at a time, so you don't forget which wires go where.
Step 8: Replace the remaining turn signal
In Part 2, where I splice in the running lights, brake and tail lights, you will only have to remove the electrical panel. The hard part is done ![]()
#10 |
Excellent tutorial ... looking forward to final installation and your full review
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#11 |
Detours,
Thank you so much for your excellent tutorial. Question - why did you have to obtain additional bullet terminals? Perhaps I'm confusing myself as I have not yet had my coffee and am just coming back from vacation and not nearly enough sleep ![]() I am looking forward to reading the remainder of your tutorial and attempting a similar installation ![]() |
#12 |
Thanks Sprite! In order to wire up the extra running light and brake light on the new turn signals, I have to tap into the stock license plate light and brake light wires.
I could have just cut and spliced the wires together, but I like to keep things as close to stock as possible. So I ordered some 3-way bullet terminals to simplify installation. http://www.ebay.com/itm/182128958020 ![]()
#13 |
ah - good to know, and I'm glad you are going this route as I hope it makes the install easier for those of us (like me) somewhat freaked out about touching the wiring
#14 |
Here's a link to Part 2! It turned out great and I highly recommend this mod to everyone!
http://www.chinariders.net/showthread.php?t=16777
#15 |
*sigh* looking through your instructions it looks like you run with no side bags on your bike, is that right?
