Old 05-30-2016, 11:33 PM   #1
xposur   xposur is offline
No spark on hawk :(
In the middle of finishing up tuning the carb the bike died after running a few minutes on idle. Wouldnt start. It cranks and turns over, has compression, spark plug is wet with fuel. I initially thought it might have been the coil, checked the resistance, and its good, then I thought maybe its the spark plug wire..swapped out the coil and wire into another bike and it was getting spark. So the coil and plug is good, fuel is good. but no spark
I really dont wanna cut into the wire harness and follow the 2 wires from coil and see if there is a connectivity issue or maybe the kill switch malfunctioned.
Any suggestions?
Old 05-31-2016, 01:04 AM   #2
CDI. Buy two.
Old 05-31-2016, 02:06 AM   #3
Johnp   Johnp is offline
Johnp's Avatar
CDI. Buy two.
Where do you get them? And is there a particular part we should look for?
John P.
2016 Hawk 250 - Black
All my mods are documented on my Blog!
My Blog | Google+ | Twitter | Facebook
Old 05-31-2016, 07:59 AM   #4
dpl096   dpl096 is offline
dpl096's Avatar
CDI. Buy two.
ditto
http://www.rickypowersports.com/#!ca...ic-parts/m0l0f
― Thomas Jefferson
Old 05-31-2016, 09:25 AM   #5
Thanks! I'm going to swap out the cdi from my other bike and see if it starts
Old 05-31-2016, 09:57 AM   #6
So I just swapped out a working CDI, still no spark. I tried removing the black and white pin out of the CDI for the kill switch in hopes of bypassing it but still no spark. The kill switch has 2 wires, one green one which I think grounds the ignition coil and the black and wire one that goes to the CDI
Old 05-31-2016, 10:24 AM   #7
humanbeing's Avatar
What's the reading(s) of pickup | source ? http://www.chinariders.net/showthrea...t=16179&page=2 #25 tells how...
Old 05-31-2016, 11:05 AM   #8
Ok, I just tested the resistance of the wire going from the stator. Using my good bike as reference, the good bike resistance the 369. The no spark bike was 132
Old 05-31-2016, 08:14 PM   #9
Is it safe to assume it's my stator?
Kill switched jumped out by putting a ground wire from negative battery terminal to coil. ✔
Ingnition coil confirmed working✔
spark plug confirmed working✔
cdi confirmed working✔
Old 05-31-2016, 09:42 PM   #10
humanbeing's Avatar
Originally Posted by xposur View Post
Is it safe to assume it's my stator? ...
Narrow it to
[Energy] Source aka exciter... Bl/R >~50V | 300-600Ω Bypass it w/ "DC-CDI" is a streetwise fix
[When] Pickup aka trigger... Bu/W >0.5V | 120-180Ω btw.This thingy is RARE to fail physically... the Gap btw flywheel | swap 2 wire's position may solve... U can't really sure what's inside in these days...
Old 05-31-2016, 10:17 PM   #11
'16 TT250   '16 TT250 is offline
I've replaced a few Honda stators, they're known to be a weak link. Not sure about other models and how durable they are. Your resistance reading being that far off makes it look like the likely suspect. The common failure with stators is that the insulating coating gets eaten up by the oil and/or heat damaged and wires start shorting out within the coil(s) lowering resistance so your finding is on par with the common stator damage.
Old 06-01-2016, 05:46 AM   #12
humanbeing's Avatar
Oh no....
According to http://www.chinariders.net/showthread.php?t=16065 , hawk = DC-CDI which similar to http://translate.google.com/translat...asp%3Fpid%3D20
How to check = There's 1?V in & 190V±20V out
Old 06-01-2016, 10:19 PM   #13
Oh no....
I checked my cdi by swaping it into another bike. It works, the only thing that had me believe wasn't working was the stator because of the low resistance
Old 09-22-2016, 07:24 AM   #14
Republic   Republic is offline
Is there a more up to date link to a CDI that will work? That rickypowersports link is broken for me.
Would this work? http://www.ebay.com/itm/6-Pins-CDI-U...ZXOuFk&vxp=mtr
Old 09-22-2016, 09:47 AM   #15
Ariel Red Hunter's Avatar
Republic, isn't this a new bike? If so, this part should be replaced under warranty.
