Old 05-27-2016, 03:55 AM   #1
Johnp   Johnp is offline
Johnp's Avatar
Hawk 250 Air Filter
Planning ahead and don't really see anyone having posted a source for an air filter. Correct me if I'm wrong please...
I pulled mine and took measurements for reference.
It appears that this Briggs and Stratton filter will kind of fit. It isn't a direct replacement, but it'll fill the hole. Does anyone know of any others that would work?
http://amzn.to/1WZj1lS
John P.
2016 Hawk 250 - Black
All my mods are documented on my Blog!
My Blog | Google+ | Twitter | Facebook
Old 05-27-2016, 04:19 AM   #2
hertz9753's Avatar
Your picture looks like a Fram air filter.
Old 05-27-2016, 05:21 AM   #3
newrider93   newrider93 is offline
newrider93's Avatar
I used a lawn mower air filter. Bought it at a local automotive store.
My YouTube channel where you can check out my hawk and other cool stuff:
https://www.youtube.com/c/Andrew93
newrider93 AKA Andrew93
Old 05-27-2016, 06:39 AM   #4
humanbeing's Avatar
Stock as some Honda in Latin America http://yiparts.com/en/dt/air_filter,...ter,c1425.html which not easy to find http://www.chyangwa.net/thread-17888296-1-1.html directly
Resourceful staff in auto parts store can find something fits https://item.taobao.com/item.htm?id=45745354191 [optional] add 1/2" thickness foam ...
Old 05-27-2016, 11:23 AM   #5
simonjester   simonjester is offline
simonjester's Avatar
Based on your photo and theirs on their site, perhaps an air filter for a TT250 will work and can be obtained from CSC?
http://www.cscmotorcycles.com/Articles.asp?ID=299
2016 CSC TT250
Old 05-27-2016, 11:52 AM   #6
Johnp's Avatar
You're right. They look remarkably alike. Probably the same thing. CSC claims they don't yet have the filters, but they are on the way.
http://www.cscmotorcycles.com/TT250-...p/zt14-104.htm
At $6.85 that's a reasonable price. Assuming they don't charge too much for shipping.
John P.
Old 05-27-2016, 12:19 PM   #7
Johnp's Avatar
Originally Posted by humanbeing View Post
Stock as some Honda in Latin America https://partsdb.info/autopart/mannfilter/c1425 which not easy to find
Thanks for the pointer. This helped me narrow things down. It looks like the Hawk uses the same filter as the Honda XR125 / NXR 125 / NXR 150. But I can't find a filter anywhere for them.
We might all be forced to either use the lawnmower air filters, or swap out to one of these things.
Oh, and since I just noticed you can't really read my dimensions well, here is the full size version of my little sketch.
John P.
Old 05-29-2016, 09:25 PM   #8
I've installed several of these, and they're quite good quality: http://www.ebay.com/itm/BLACK-42mm-B...FUi8Cu&vxp=mtr
Old 05-30-2016, 09:37 AM   #9
Johnp's Avatar
How much louder does it generally make the Hawk? And do you need to rejet and/or do anything with the exhaust?
John P.
Old 05-30-2016, 11:20 AM   #10
I can't hear it over the Honda CRF250X muffler I welded on. Yes, you need fatter jets any time you increase air flow. You can certainly use a pod filter without changing the exhaust, but you should still expect that jet changes will be needed.
Old 07-27-2016, 12:42 PM   #11
jimwildman   jimwildman is offline
jimwildman's Avatar
If that B&S filter will fit..
  • Replaces Briggs & Stratton Service Part #491588S
  • For 3.5 through 6.75 Horsepower Quantum Engines and 625 through 1575 Series Engines
According to the K&N cross reference chart here;
http://www.knfilters.com/industrial.htm
This one should fit, and is a lifetime type filter that does not require oiling.
http://www.knfilters.com/search/prod...x?prod=33-2238
Has anyone tried the B&S replacement? can you describe the fitment?
I'd buy one of the K&N and give it a shot if someone can vouch for the fitment.
Last edited by jimwildman; 07-27-2016 at 01:02 PM. Reason: correction. filter does not require oil.
Old 07-27-2016, 02:04 PM   #12
SeerAtlas   SeerAtlas is offline
while you're looking at filters, Motocheez did an airbox mod in one of his videos, my bro tried it before this morning's ride. for whatever reason, his immediate reaction after passing me at about 55 true going UPHILL, was "WOW".stock carb, stock exhaust. claimed he got 6 or 7 mph on top end with torque to match. he's running a 16/45 combo. I can tell you I was surprised when he went by (was on my Triumph T-Bird) and he sounded like a 350/400
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 07-28-2016, 11:46 AM   #13
ckrug4   ckrug4 is offline
I took a good quality pleated air filter and cut it to fit my air box. Doubled it up with a little hardware cloth under it for strength. So far so good. Drilled a few good sized holes in top of box. The Briggs n Stratton did look to fit the box but it was $7. The ac air filter was $4 and I have enough material to make several filters.
Old 07-28-2016, 09:00 PM   #14
jimwildman's Avatar
I ordered the k&n so when it comes in ill report back on the fit, and such, take a few pictures.
If it dont fit the bike it will fit my lawn boy so no harm no foul.
Old 07-28-2016, 09:04 PM   #15
pcspecialist   pcspecialist is offline
I ordered the one from CSC, when it arrives I'll let you know if it is the same size as the Hawk filter though I'm pretty sure it is. According to the tracking info, I'll have it this Saturday.
