Old 05-12-2016, 11:18 PM   #1
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
Exhaust Clamp Bolt Broken
The bolt that tightens down the muffler to the header pipe just broke right in half.
So the other day, the woman comes in and says she thinks the muffler seems a bit wobbly. I dismissed it as, all mufflers kinda wobble, especially on a thumper.
Well, I decided to go check, sure enough, it's a wobblin'. But the cause was not what I thought. Here I was thinking hanger bolts. Nope, it was loose at the flange where it slips on over the header pipe. OK, no big deal, I'll just grab a 10mm socket and tighten it back down... SNAP! The stainless steel bolt just snapped in half as I was applying pressure. Now I was only using 1/4" drive, and I'm still recovering from carpel tunnel, so there was no way I was wrenching on it that hard.
Anyway, just thought I'd let you guys know to check that bolt from time to time. I'm pretty sure the heat cycles have tempered the stainless bolt to a brittle state.
Old 05-13-2016, 12:23 AM   #2
Thanks for posting the warning.
Old 05-13-2016, 11:09 PM   #3
Jay In Milpitas's Avatar
Pictures of the bolt?
Old 05-13-2016, 11:24 PM   #4
dpl096   dpl096 is offline
dpl096's Avatar
Warning
Yes.., ditto Spud - thank u
― Thomas Jefferson
Old 05-13-2016, 11:31 PM   #5
Eco Mouse's Avatar
Sorry, I chucked the bolt... but it's right above your right side foot peg. Can't miss it. It's a fancy hose clamp looking thing.
The bolt head is 10mm, and the thread is 6mm at a 1.0mm pitch. I couldn't find an 8.8 grade replacement bolt that had long enough threads, so I ended up getting a cap screw and a pan head. Both with hex-key/allen holes.
Something that I did notice, is that the barrel that the bolt threads into on the other half of the clamp, is also stainless. And the threads were really galled up. Stainless has a habit of doing that. So... if you guys go to check that bolt, and can get it off without twisting it in half, I suggest you dip that bolt in some Milk of Magnesia before threading it back on. That will keep the threads from galling. Or, you can use a different type of steel bolt, and not a stainless one. Which is what I did.
Old 05-13-2016, 11:37 PM   #6
detours   detours is offline
detours's Avatar
Thanks for the heads up on that bolt!
Red 5 standing by!
2014 Ural Patrol
Old 05-14-2016, 12:06 AM   #7
Thanks, I understood the location. Was hoping to see if the bolt displayed signs of distress.
Old 05-14-2016, 12:25 AM   #8
zingshoen   zingshoen is offline
zingshoen's Avatar
chinese steel? "steel"?
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 05-14-2016, 01:44 AM   #9
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
The problem is not (Chinese) steel, but as Eco Mouse explained, the choice of a SS bolt in a SS "nut".
1. SS in SS will gall and seize, resulting in the bolt "twisting off".
2. The yield strength of SS bolts is 60% of a Grade 2 bolt - my local hardware store doesn't even sell Grade 2 bolts because they are so inferior. A Grade 5 bolt has 160% the strength of a Grade 2, and 260% the strength of a SS bolt.
Dan
CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650
