Old 04-28-2016, 09:17 PM   #1
closedquestion   closedquestion is offline
Thought the Hawk came with a 50tooth sprocket?
Was outside doing some tinkering on the Hawk this afternoon. Decided to put the 17tooth sprocket I had ordered on, and look at the rear as well. Also bought a 45 for the rear. As I was loosening the axle nut something on the stock rear sprocket caught my eye. Stamped on the back is "45#". Does this mean I already have a 45 tooth on there? Nuts! Haha! Well, came in to eat dinner and post this. Back out to finish the 17tooth swap in a bit.
Old 04-28-2016, 09:43 PM   #2
humanbeing's Avatar
"45#" maybe the type of steel
http://baike.baidu.com/view/1213872.htm Chinese "GB" 45 = German "DIN" C45...
Old 04-28-2016, 10:07 PM   #3
lefty   lefty is offline
Mine Says "420 50t" and I count 50 Teeth is the bike new to you or used?
Best,
Lefty
2015 Hawk 250
1982 GS1100L
1983 Honda 185s 2ea.
1974 Puch 175mx
1972 Honda CT70
Old 04-28-2016, 11:04 PM   #4
Count the teeth
Old 04-29-2016, 12:05 AM   #5
The number of teeth should stamped on the front, not the back of the sprocket. When in doubt, count the number of teeth.
Old 04-29-2016, 02:23 AM   #6
paulesmann   paulesmann is offline
paulesmann's Avatar
It's a 50t sprocket. Mine has the same 45#
Paul Mann
2015 Haosen Hawk
1989 Kawasaki EX500
1991 Suzuki DR350
Old 04-29-2016, 12:46 PM   #7
Fame28   Fame28 is offline
I also thought the same thing initially and then I counted the teeth, it's a 50 tooth with a 45# stamped on the backside... Somehow mine was actually warped from the factory, just strange to think something that thick would be bent just manufactured.
Old 04-29-2016, 02:13 PM   #8
Indeed, that is amazing. I hope you saved that sprocket, or at least captured a photograph of it.
Old 04-29-2016, 06:50 PM   #9
I still have it and having two hawks and swapped the sprockets on both, we compared my 50 tooth to the other bike and you can see it's "warped". If I ever think of it, I will have to take a picture of it.
