04-28-2016, 02:08 PM | #1 |
Chain wax -vs- Chain lube
Anxious to hear everyone's input as to which they feel is better or should both be used together ?
04-28-2016, 03:00 PM | #2 |
I use wax. Seems to hold better. You will get every response you can imagine. Some use one, some the other, some use none. I use the wax. I only clean my chain every few thousand miles. I use mineral spirits,use wd40 to displace the water, wipe it off, let it dry. then wax. The wax seems to hold better on a warm, freshly ridden chain, so I do it after I ride, or every couple hundred miles, or after a ride in the rain. I use Belray wax.
I tried Lucas chain lube, and that stuff flung EVERYWHERE. I would not consider using it again. My back wheel was black. I want the product to stay where it's going to do some good. |
04-28-2016, 03:08 PM | #4 |
I like Maxima Chain Wax, and one of the reasons is that it doesn't end up on the back of my jacket.
04-28-2016, 04:27 PM | #7 |
Whatever is Valvoline White Synthetic. Clean with WD40, spray on. Holds fine and no dirt magnet.
Of course this topic is almost as controversial as the dreaded "wich oil", but it's always good to gather statistic group knownledge... and then do whatever suits you, anyway haha |
04-28-2016, 05:00 PM | #8 |
If you are riding off road in dusty conditions, definitely use wax rather than oil. If you ride exclusively on pavement, some people actually install a chain oiler.
I only use X-ring (O-ring) drive chains on my motorcycle, since they are self lubricated. Whenever I wash my bike, I remove the water and clean the O-rings with WD-40. If the chain is dry, I also clean the O-rings with WD-40. Then I apply a small amount of 90W gear oil to the bushings and rollers of the drive chain. You don't need to lubricate the O-rings; you only need to keep the O-rings clean, and supple. However, you should always lubricate the rollers and bushings of any drive chain.
04-28-2016, 06:53 PM | #9 |
I spray Maxima chain wax on my chain every 300-500 miles. Over time, the original oil/packing grease gradually goes away and I'm left with a clean chain that doesn't attract dirt.
I started using spray-on chain wax on my mountain bike years ago. Dirt and dust just accelerate wear, and the last thing you want is to attract it with a wet lube. Anyway, works for me in Denver's dry climate.
04-28-2016, 08:46 PM | #11 |
Being in a Dusty/Dirty environment, I use Finish or Maxima Chain Wax, I order whatever one is less expensive at the time I need more
04-29-2016, 05:44 AM | #12 |
i use this... was turned on to it by fellow road bicycling friends, and it works wonderfully for motorcycles too... its a penetrating paraffin wax...and you can use it on damn near anything that is supposed to be able to move...LOL
http://boeshield.com/bike/ |
04-29-2016, 10:54 AM | #13 |
I use this. Works great, doesn't fling, affordable....and delivered to Volcano for free! Saves me a bunch in gas right there......
http://www.amazon.com/DuPont-Chain-S...ilpage_o00_s00
09-10-2016, 07:34 AM | #14 |
has anyone had to replace rear sprocket yet on there Zong i have 3500 miles starting to wear the links on chain, sprocket looks fine was going to just replace chain but some people say replace both at same time remember i am a newb just thought if chain is sub standard would wear before sprocket?
Peace and Zong Life
09-10-2016, 11:18 AM | #15 |
Willy Dog, the chain and both sprockets act as a system and that's how you should treat them. A worn chain will have more distance from pin to pin so instead of putting even pressure on all the sprocket teeth you get a situation where all the force is being carried by fewer and fewer teeth. It might not look like the teeth are wearing but they are. If you just replace the chain because the sprockets look so good you are actually shortening the life of the new chain. As Joe noted in his book, 5K @ 8K, the OEM chains only lasted about 5K miles before they were totally shot. The sprockets were not much better. CSC sells an upgraded chain at a good price (less than $150 for X-Ring chain and both sprockets) and I'd expect to get at least 10K out of that setup....maybe double that if you really take good care of it. My last Ducati went 20K miles on one set of chain and sprockets but I was also using an automatic oiler.
