Alinement and Camber.. Heres a thread,
Ok alinement and camber is not right from the factory.. I played with it.. took a handle bar to the gut a few times.. I guessed after that... I needed help
![]() So I looked until I found this.. lots of crap but this is simple.. http://www.atvrider.com/toe-and-camb...ight-talk-tech Ok here is my issue... The ball joints on my quad do NOT have nuts to adjust them up or down... one tire is pretty darn close other one is way off. I am trying to figure out what is different, what is wrong. how to get this tire to lay down.. the tire is straight up and down... ![]() any ideas? |
Thank you for posting this. I just put shocks on that dropped the rhino down about 2 inches and had to adjust toe and camber on it. Sorry, no ideas to help you but I will check on link to see if i need to re adjust something!
how did you adjust the camber.. Am I missing something? Is there lock nuts on your quad to adjust them??
#4 | |
There is no caster adjustment as the control arms are fixed in position.
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 12-31-2016 at 03:42 PM. |
#5 | |
YEP YEP.. I am missing something.. MY TOP LOOKS JUST LIKE YOUR BOTTOM.. Top and bottom... I thought there was a lock nut under the rubber boot I was missing.. I even loosened it and pulled it out a bit to check... ![]() ![]() ![]() Thanks for the pic.. I would not have believed that they where different.. I mean really??? LOL thanks again |
Can you post a picture of what you have ?
yes I will.. just got home from this side job I got.. check back later tonight..
