Old 04-16-2016, 05:38 PM   #1
closedquestion   closedquestion is offline
Is Hawk gas cap universal size?
I have been going through and figuring out and eliminating buzzes and other annoying noises coming from the Hawk. I'm down to the last and most annoying buzz. It's coming from the flap on the gas cap. I can't figure any way to fix it, as I think the flap is rivieted. As long as I hold my hand down on the flap, no noise. I can also eliminate most of the buzz if I turn the flap to the side. I'd rather just have no buzz, and flap stright if possible. Thanks for any ideas.
Old 04-16-2016, 08:39 PM   #2
SeerAtlas   SeerAtlas is offline
i think i am confused? do you mean the metal tab that swivels to cover the gas tank keyhole?
if so, something is different . neither of ours is loose enough to vibrate er go no noise.
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 04-16-2016, 10:48 PM   #3
Mag00   Mag00 is offline
Do you have a picture? Yours is most likely different than my Storm, but maybe not.
Bashan 250 Storm
Husqvarna TR650
Honda Metropolitan
Be a Piggy!
Old 04-17-2016, 12:13 AM   #4
paulesmann   paulesmann is offline
paulesmann's Avatar
Yeah I have the same problem on my haosen
Paul Mann
2015 Haosen Hawk
1989 Kawasaki EX500
1991 Suzuki DR350
Old 04-17-2016, 08:43 AM   #5
Hancadam   Hancadam is offline
My buzzes like crazy. But I found it's not the flap since I cut mine off and it still buzzes. Would like to find another.
Old 04-17-2016, 02:56 PM   #6
Yeah, I'm thinking it's the flap. It seems to be getting looser as Now even when I have it off to side it buzzes. I was going to try a super thin piece of "cardboard"paper, cut into a small square, and place betwwen flap and cap. The dental floss idea is a good one as well. All I can say is its a horrible buzz, and I wont stop until it's gone. Haha! Otherwise the Hawk is sounding great!
Old 04-17-2016, 03:23 PM   #7
Adjuster's Avatar
Need photos.
Old 04-17-2016, 09:02 PM   #8
So this is a stock photo from the website I bought the Hawk from. I am certain it's the keyhole flap. Horrible buzzing, if I even lightly put my finger on it, it stops. So, I'm either going to have to find something to "jam" in there to keep the buzzing down, or try getting the flap off.
Old 04-18-2016, 03:16 AM   #9
humanbeing's Avatar
Most of this style =
As found on "ancestor" JH125L http://forum.jorsindo.com/forum.php?...rtype=1&page=1 (based from 80s XL125S)
Honda Twin: CB125T, CM125... Thumper: MCR125 , CGR125 & tons copycat...
"Buzz" is a common topic discussed in "MCR" board http://www.chyangwa.net/thread-604136-1-1.html | http://www.chyangwa.net/thread-90120-1-1.html
Typical syndrome appears when 4.2-5K rpm / tank isn't full...
Solution: Use something such as http://hengdatech.gmc.globalmarket.c...e-1374748.html glued that "fuel proof material" stop the buzz
Old 04-18-2016, 05:09 AM   #10
As always, thanks for posting the great information, HB.
Old 04-18-2016, 09:01 AM   #11
zingshoen   zingshoen is offline
zingshoen's Avatar
or tape some duct tape over the underside, that ll stop the rattle, make sure u don t cover the venthole if that s how this tank is vented
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 04-18-2016, 09:57 PM   #12
farmbath   farmbath is offline
Mine is quite.
Old 04-18-2016, 10:45 PM   #13
HB...Great research as usual !
Old 04-18-2016, 11:08 PM   #14
humanbeing's Avatar
Sometimes front cushion (Honda: 17611-286-000) cracked & "magnifies" those annoying buzz...
Quick & free solution: Replace it w/ a chunk of rubber thingy (non-function inner tube, old fuel line...) stops the headache....
Old 04-18-2016, 11:42 PM   #15
Thanks everyone for the ideas, HB is the winner of the diagnosis. Since I got the Hawk I have been chasing down the little squeaks and buzzes, I realized today that the gas cap buzzing was a fairly new issue and the last one I had. Last night I tried wedging a couple super thin vinyl disc( think the little disc on a glass coffee table between glass and frame) it actually made the sound worse. I realized the "flap" has a lot of free play, on purpose, for snags and what not. While the buzzing is coming from the flap, it's the overall vibration of the cap that is the issue. I stopped to get gas on the way home, no buzz on the rest of the ride home. So as HB posted from other forums folks having issues when their tanks were not full, also appears to be my issue as well. I'm going to give a little thin foam weatherstripping a try under the cap area around the mouth, and hopefully that will do the trick. Thanks again all!
