Old 04-16-2016, 01:17 AM   #1
mq1991   mq1991 is offline
Battery Replacement
So my battery isnt really holding a charge any more. Do you guys know if this battery will fit?
I tried measuring the current battery, but its hard to know is Amazon's measurements are correct.
http://www.amazon.com/YTX7L-BS-High-...rcycle+Battery
What batteries have you guys used to replace the stocker?
Old 04-16-2016, 05:03 AM   #2
79elco   79elco is offline
I think these folks might be able to help.
https://www.batteriesplus.com/batter...cycle/show-all
Old 04-16-2016, 06:12 AM   #3
lee47512   lee47512 is offline
Did you cross reference with the number on the battery? If that is what came up then yeah it should fit.
Lee
2014 powermax 150.
2015 Hawk 250.
Poop happens
Old 04-16-2016, 09:45 AM   #4
I've had good luck with the (N)Everstart's from Wally World. You just have to really follow the directions regarding allowing the proper soak time after filling and don't use over a 1.5 amp trickler when doing the initial charge. I cheated that system once and it didn't last near as long. I think it's because they're filled with shock resistant foam or something.
Old 04-16-2016, 09:52 AM   #5
Azhule   Azhule is offline
Might I also suggest getting a multi-stage Battery Tender with a DeSulfate phase, almost every battery that I had that was "dead/dying/wont hold a charge" was due to Sulfate build up on the plates... leaving them charge in 'desulfate mode' overnight has brought back to life almost every battery I have attached it to so far.
3 motorcycle batteries (7ah and 14ah, one made in China, one Japan, one Mexico), 2 riding mower batteries, countless car/truck/automotive batteries, I also recently revived a 8 year old Optima Red Top battery.
I would give 3 to 1 odds that a Battery Tender with a DeSulfate mode will get several more years out of your current batteries
Old 04-16-2016, 09:59 AM   #6
Isn't it shocking how much less expensive a huge lawn tractor battery is than a tiny little motorcycle battery? I think the second they put the word "motorcycle" on anything, the price goes up....
Old 04-16-2016, 02:25 PM   #7
Thanks everyone for your input, I ordered both a desulfator and the new battery. Ill report back on my findings. The battery is half an inch taller than the stocker, but it should JUST clear the airbox. Fingers crossed!
Old 04-16-2016, 03:10 PM   #8
dpl096   dpl096 is offline
dpl096's Avatar
battery
We dont have that retailer in my neck of the woods but we do have someone very similar - Battery Specialist - a small chain in the central Illinois area - remanufactured/recycled batteries ...... I've used them on and off for nearly 30 years and cant seem to learn my lesson - Unreliable as a damned politician ! Besides name brand I've had excellent luck with Walmart batteries ...shocking but true!
Old 04-17-2016, 12:06 AM   #9
mjstef   mjstef is offline
I read somewhere that a guy was running some sort of Lithium Ion battery in there bike. I personally will go with an Odyssey if i can find one that fits. LOVE them in my plow truck.....
Old 04-17-2016, 01:11 AM   #10
If you get one, do not use a Battery Tender with Desulfate phase on a Lithium Ion Battery, fastest way to kill those expensive Lithium batteries is to attach them to the wrong charger/battery tender (and most if not all of them with a Desulfate mode is the 'wrong kind of charger')
Old 04-17-2016, 07:43 AM   #11
dpl096's Avatar
tender
Thanx for the heads up ! 2 years ago I fried a new battery on a battery tender jr and have blamed it on the battery since ... now I know better ....
― Thomas Jefferson
Old 04-20-2016, 10:52 PM   #12
Just a quick update, the battery is toast, one dead cell. The desulfator didnt have a chance :(
The new battery works great on the other hand. It fits the stock battery box differently then the stock battery, but it does fit. Some extra strapping/padding is recommended though.
Ill grab some pictures if anyone is really interested.
