Old 04-15-2016, 09:28 PM   #1
indicator lights...pretty dim
Maybe I have a problem, maybe not. The various indicator lights on the dash are virtually non existent in any kind of light. This means the turn signals, high beam and who knows what else. None of them are bright enough to see in daylight. I can live with this but if there is a solution I'm all ears. Could I have disabled a ground when I installed the windscreen?
Peter y.
Old 04-15-2016, 10:08 PM   #2
Huck369   Huck369 is offline
Huck369's Avatar
I had the same complaint when I first got my RX-3 , but I guess I've just got used to not seeing them well.... would like to know if someone has a fix for it too...
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 04-15-2016, 10:30 PM   #3
Azhule   Azhule is offline
Does it have Glass fuses?
Had dim looking lights on a '99 KLR650 and also the Bashan BS200GY-9 I recently received, replacing the Glass fuses with ATC/ATO fuses fixed it... don't know if the same applies to your situation/bikes but it might be something to look into
Old 04-15-2016, 11:12 PM   #4
Peter y.
You didn't disable a ground connection, or do anything else wrong, Peter.
If the LED lights are colored, and not white, here is a possible solution.
The indicator lights on the right of the dashboard are covered with a film which contains silhouettes for the turn signal arrows, et cetera. If you remove that piece of film, the indicator lights should be much brighter. You will lose the symbols, but we know the colors for each symbol, so the symbols aren't really necessary.
Top Green: Turn Signals
Blue: High Beam Indicator
Yellow: Low Fuel Warning
Bottom Green: Neutral
Red: Engine Warning Light, DTC Indicator
Old 04-16-2016, 12:09 AM   #5
Jay In Milpitas's Avatar
Peter y.
Unfortunately they are low output LEDs. Unless you are proficient at neurosurgery and can do a transplant, one just has to live with them.
I have developed the habit of looking at the top edge of my turn flasher to see it it/they are on. The rest I don't really pay attention to, and I'm actually glad the Low Fuel flashy thing isn't too visible. I can see the blinking bar just fine on the fuel gage.
Old 04-16-2016, 01:09 AM   #6
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
DTC?? Dynamic Traction Control?
Dan
CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650
Old 04-16-2016, 02:45 AM   #7
DTC = Diagnostic Trouble Code
Old 04-18-2016, 01:43 PM   #8
keithmaine's Avatar
Bobrx
added some led indicator lamps to his dash, which I will be adding soon. His website has the info on how he did it.
Old 04-18-2016, 10:47 PM   #9
RedHawk47's Avatar
Originally Posted by keithmaine View Post
Bobrx
Link?
Dan
Old 04-18-2016, 11:20 PM   #10
AZRider   AZRider is offline
http://www.rx3adventure.com/rx3_dashboard.html
George
2016 CanAm Spyder F3-L
