Old 04-15-2016, 07:20 PM   #1
eco4arcs   eco4arcs is offline
hawk stock exhaust question
If i unscrew the muffler cap and remove the hitech mesh baffle will i reap any performance benefits beyond the more satisfying sound?
Any jetting change suggestions? Running 115/30 now.
thanks
Old 04-15-2016, 08:02 PM   #2
farmbath   farmbath is offline
I couldn't tell any difference other than the sound is better.
Old 04-15-2016, 08:08 PM   #3
Sport Rider's Avatar
I punched mine out with rebar and probable gained 5 HP on it!
</sarcasm>
:-D
Seriously...nothing of consequence gained.
Old 04-15-2016, 09:46 PM   #4
hell, sport rider says it's true (5 hp), in fact sign him up for a late nite infomercial (make sure to use the British accent)
Old 04-15-2016, 10:20 PM   #5
Azhule   Azhule is offline
Depending on the design of the HAWK exhaust I'm sure a few ponies can be gained depending on what all you change/remove from the restrictive exhaust, just look how nasty and restrictive the Bashan header is and the muffler is no better
First they jam some kind of Coil/Spring/Soda Can inside for your exhaust gasket
Then they do a crap job and weld the INSIDE of the header making it at least 2/3rds as restrictive as it should be
Old 04-15-2016, 10:37 PM   #6
lee47512   lee47512 is offline
Do you have all the clean air stuff? evap and egr stuff? That looks to be a catalytic convertor my hawk has none of that at least I don't think so.
Lee
2014 powermax 150.
2015 Hawk 250.
Poop happens
Old 04-15-2016, 11:24 PM   #7
Yeah my bike came with most if not all that nonsense, the header also has a small sound dampening Baffle/Restriction built in it shortly after the "Big Egg/Catalytic Converter".
I'm sure after I change out the exhaust and tune my 197cc Bashan properly I could see an extra 5 - 20% (if not a little more) HP and Torque across the entire rev range... but it was extremely restrictive compared to others from the looks of things
Old 04-15-2016, 11:34 PM   #8
I knew it!!!
Old 04-15-2016, 11:55 PM   #9
yes, definitely help you in your mile high zone.
anything possible, think wide nonrestrictive stainless tube, smooth inner bore. (give me money, lots of money.) someone will take a poke at it, too many people signed up recently (gear-heads cant resist).
Old 04-16-2016, 06:15 AM   #10
I knew it!!!
Didn't he go to jail for pot or something lol?
Lee
2014 powermax 150.
2015 Hawk 250.
Poop happens
Old 04-16-2016, 09:54 AM   #11
To the best of my knowledge, we don't have dyno numbers on the Hondoid pushrod motor regarding HP gains with mods but they are available for the Q 200 OHC motor. Using that as a comparison,....proper jetting and exhaust mods did give a full 5hp gain from 15 to 20....and for those who have been asking, this is what an FMF Turbine Core 2 sounds like. I will say this...putting a breather, proper jetting and a slip on pipe (no cat) on all of my Hondoid pushrod motors has definitely increased the performance.
Old 04-16-2016, 10:39 AM   #12
Those Zong OHC engines are 'fairly cheap' to get too, under $700 shipped for the air cooled ?223cc? version, and it should bolt right in place of my current pushrod motor/frame mounts if my measurements are correct (drool). Once the Mrs. gets used to riding a motorcycle I might have to swap out for a bigger, better, more powerful Zong OHC engine (or a different bike all together )
But back to exhausts, does anyone know if the HAWK and Bashan exhausts are "interchangeable"? The inexpensive and free(er) flowing HAWK exhaust would be a nice addition to any restrictive Bashan Dual Sport... but are the measurements and frame design similar enough to work?
I'm also looking into a FMF PowerBomb Header off a few different Honda's, if any of them measure out right I might be able to pick one up for as 'little' as $150
Old 04-16-2016, 01:30 PM   #13
ughmas   ughmas is offline
ughmas's Avatar
nice sound... I think you officially sold me on the TC2 for my tt250 in due time. I wasnt sure how a 2-stroke pipe would sound on a four stroke.
2005 CBR600RR
2016 CSC TT250 Coming Soon
Old 04-16-2016, 05:06 PM   #14
Jayman77   Jayman77 is offline
Jayman77's Avatar
Yeah but I bet he could sell the heck out of the stuff
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 04-16-2016, 05:17 PM   #15
About 7 years ago I installed an FMF Universal Spark Arrestor on my Zongshen Sierra 200. This silencer meets U.S.F.S. requirements for sound levels, and a spark arrestor. It increased the power output from the engine, and dropped a lot of weight from my motorcycle. It is well built, and easy to repack. I am very glad I installed it.
http://www.chinariders.net/showthread.php?t=7196
