Photo Gallery: Show Us Your Zongshen RX3, and List Your Modifications
Show us your Zongshen RX3, and list the modifications you have made to personalize your bike.
![]() ![]() ![]() ![]() ![]() Here is the list of modifications to my RX3. Custom Paint Job (Patriotic Blue) Accessory Power Outlets SpeedoDRD 55W/60 H4 Headlight Bulb Trimmed Back of Headlight Housing to Dissipate Heat from H4 Bulb Tusk D-Flex Handguards Tusk 1-1/8" (30 mm Height) Handlebar Risers Mobil1 Synthetic ATF Fork Oil Tractor Supply Auxiliary Flood Lights SuperBrightLEDs Auxiliary Spot Lights Honda CRF250X Sintered Brake Pads for Front Brake RAM Handlebar Mount for Garmin eTrex Legend GPS Receiver Oxford Premium Touring Heated Grips Grab On Foam Grip Covers Modified Headlight Switch Modified Fuel Gauge Sender to Flash Empty after using 2.9 Gallons of Fuel Honda XR650L Folding Shift Lever 13T/46T Sprocket Combination RK 520EXW Drive Chain 2nd Generation CSC Center Stand CSC Progressive Shock Absorber Garage Pro (JC Whitney) Travel Trunk Relaced Rear Hub with Warp9 Rim, size 2.50-17 Installed Japanese Wheel Bearings in Rear Wheel Hub Shinko 244 Rear Tire, size 4.60-17 Shinko 244 Front Tire, size 3.00-18
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 04-10-2016 at 07:51 AM. |
This is my bike. I purchased it new in September 2015. Approaching 16.000km.
I'm from Argentina, and here it's the carburated version, which comes with a rear 15' wheel - Larger topcase, I commute to work and need to carry my notebook backpack. - Winyoochanok windshield and handlebar risers. - I just changed the rear rim to 215 x 17 in order to fit "standard" tires, shown with Metzeler Tourance 120/90/17 (already bought 185 x 19 front rim, will change soon) - Aux LED lights. - USB/12v over dashboard, both fed from independent line from battery with fuse and relay. - Handlebar GPS mount. - Handlebar end weights, also cut about 3cm each end, so current width including weights is the same as before. - Mirrors from Honda NX400 (bigger and rectangular shape). Very sturdy, very little vibration even at "full speed". - Front 15 tooth sprocket, rear standar 41. - DID VX520H final chain (original worn out). - Custom made centerstand. - Front brake pads, origin Brazil, from Honda XR250. - Bixenon headlight bulb. - Small lens LED in place of the blue plastic cover inside headlight. - Modified wire so dashboard lights up upon turning key on. |
No pics of mine...all I have is an invoice
![]() Sorry to bombard you with questions, but you seem to have the mods I have on my DR, and or want on the RX3. |
Spud, looks good.
I don't see the csc badge, am I missing something?
#5 | |
![]() I bought the eTrex Legend primarily for dirt riding, because it is small and robust. I do use this GPS receiver while traveling on pavement. However, since the screen is small, I frequently need to pull off the road, and stop, to properly view the display. The eTrex Legend does give visual, turn-by-turn directions when approaching intersections. However, it does not give you an audio alert. ![]() The eTrex Legend GPS receiver has been superseded by the eTrex 20X receiver. https://buy.garmin.com/en-US/US/into...rod518046.html ![]()
#6 | |
![]() I have Zongshen roundels for my RX3. ![]() ![]()
What brand paint did you use Spud? I'm tempted to plasti dip mine to a dark grey/green metallic. I'm not sure about the durability of the stuff though.
Green and Camo RX3
I couldn't upload the pics, but on Taobao, there is a green RX3 and a Camo version available. The green looks like the Triumph Tiger green. Very nice. |
#10 |
https://flic.kr/p/A7gRDP
My mighty RX3 purchased June 25 with >5,500 Smiles Tall Seat (Seat Concepts) Center Stand (CSC) Hand Guards (CSC) Heated Grips (CSC) 10W Cree lights (CSC) RAM mount (garmin)
Dave |
#11 | |
![]() http://www.krylon.com/products/fusion-for-plastic/ I then sprayed most of the parts with Krylon Fusion Clear Coat, which provides UV protection. ![]() http://www.krylon.com/products/fusio...plastic-clear/ I painted the RX3 fuel tank and plastic 'wings' with SprayMax 2K Clear Coat, which is fuel and UV resistant. I wore a 95P respirator while spraying this product. ![]() http://www.spraymax.com/index.php?id=361&L=1 Here are several photos of my Zongshen Sierra 200 (ZS200GY-2), showing the Patriotic Blue color in brighter light. ![]() ![]() ![]() ![]()
#12 |
Spud ,thanks for creating this photo gallery. It will be great to see all the mods and colors people come up with. How much overall speed you loose going from "fastest orange" to "Patriotic Blue" ? rj
Live Zong, and Prosper |
#13 | |
![]() Much to my surprise, I discovered blue is as fast as orange. ![]() ![]() ![]()
#14 |
#15 |
![]() Sorry for the busy pic, but here's my farkles on my bike. - Winyoochanok smoke windscreen - CSC Auxiliary Outlets - GPS handbar mount - Tusk 30mm risers - Cree LED H4 36W, 3200 lumen headlight bulb - Trimmed back of headlight assemble for H4 incandescent cooling (good for H4 mod also) - Auxiliary Lights: 2x4" 18W 6 Cree LED Spot Lamps - CSC Big Brake Kit with Sintered Pads - CSC Gen 2 Center Stand - Akrapovic slip-on muffler and custom mid-pipe - Header wrap (for larger diameter custom mid-pipe) - 42 Tooth rear sprocket (for lower RPM highway cruising) - Black reflective wheel stripes (better side visibility at night) - Reflective tape on panniers and top case |
