Old 04-07-2016, 12:37 AM   #1
Aleong1967   Aleong1967 is offline
Headlight Adjustment and Aux lights
Does anyone know if there is headlight height adjustment on our headlight assy?
Tonight was the 1st night I rode the bike at night
The LED replacement works nicely, but is a little low
The is alittle play in the assy, so I tilted up as much as I could, still to low for my feeling
Also I got the 30 watt Aux lights that CSC offers
I know they are somewhat pricey, but they work GREAT
They really light up the road
Old 04-07-2016, 01:03 AM   #2
rjmorel   rjmorel is offline
rjmorel's Avatar
I believe the only adjustment is by loosening the 2 bolts on side of headlight and pivot it where you want the light then tighten it back down. I stuck some stiff foam between the headlight and top fender so it wouldn't vibrate back down. rj
Live Zong, and Prosper
Old 04-07-2016, 01:32 AM   #3
detours   detours is offline
detours's Avatar
Like RJ said, you have to aim the whole assembly. I recommend a mild thread locker for those bolts. They can rattle loose on bumpy dirt roads.
Red 5 standing by!
2014 Ural Patrol
Old 04-07-2016, 01:41 AM   #4
That's what thought
I actually put a foam weatherstrip spacer between the headlight and fender also
Glad I got the Aux lights to help light up more of the road
Old 04-07-2016, 11:45 AM   #5
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
Which LED headlight did you get?
Does it have low beam cutoff?
How is the light pattern? The one I tried put out lots of light, but not in the center of the beam.
Dan
CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650
Old 04-07-2016, 07:53 PM   #6
I have the one that CSC offers
Can't say if it better the the original because I never had the original
Light pattern was fine
My issue was it was too low in front
But once the driving lights are on the fill out the rest of the space
