Old 03-22-2016, 08:14 AM   #1
Joyrider   Joyrider is offline
Lexmoto Assault Carb
Hi there, has anyone else got one of these models. Ive had mine for 3 weeks and just wondered why the carb hasn't got a mixture screw, just an idling screw, Phil
Old 03-22-2016, 11:09 AM   #2
Not sure about the bike you have but in general, most carbs now-a-days come all sealed up and non-adjustable for EPA and/or CARB requirements. They make them super lean and then don't let you mess with them. Does it have float bowl screws? That's an indicator.
Old 03-22-2016, 02:24 PM   #3
Thanks for that 2LZ. I've just had a look and there isnt any float bowl screws, Phil
Old 03-22-2016, 03:54 PM   #4
What size bike is it? 200? 150? Hondoid clone?
Old 03-22-2016, 04:41 PM   #5
humanbeing's Avatar
http://www.lexmoto.co.uk/HJ125-J.php | Made by http://www.tayomotor.com/
What's the brand [TK / Keihin (& clone) / Mikuni] & model of that carb? Can u show us some pics?
Old 03-22-2016, 07:24 PM   #6
Its a 125, its branded in England as a Lexmoto Assault.
Old 03-22-2016, 07:52 PM   #7
You have the best looking bike of all their models which are very smart looking. lz is correct about the non a just able carbs. This trend began in the 90's here in the states with sealed up 2 stroke string trimmer carbs. Are motorcycles required to be emissions tested periodically in the uk?
Old 03-23-2016, 03:04 AM   #8
Thanks for that website humanbeing, I was wondering where they originated from, looks nice in red, we over here only got a choice of black or blue. As far as I know there are no periodic checks for emissions on motorcycles as yet, Phil
Old 03-23-2016, 05:32 AM   #9
humanbeing's Avatar
According to domestic record http://www.vecc-mep.org.cn/static-we...II-113-MT1.pdf . It's a Deni (http://www.dekni.com | Keihin used had some shares https://www.keihin-corp.co.jp/english/news/pdf/ar09.pdf in o days) CPZ26 http://item.taobao.com/item.htm?id=40023356716
Old 03-23-2016, 08:47 AM   #10
Tranberg   Tranberg is offline
If it uses the same large diameter (6.9 mm) Keihin jets as Sheng Wey, getting them will prove to be hard and expensive.
http://chinariders.net/showpost.php?...0&postcount=15
OVERALL LENGTH = 8.5 mm
SHAFT DIAMETER = 5.5 mm
DIAMETER OF THREAD = 6.9 mm
KEIHIN 99101-124 and 99101-ZF5
£22.5 will get you this, which uses Mikuni jets: http://www.ebay.de/itm/172125406663?...174&rmvSB=true
Old 03-23-2016, 10:08 AM   #11
humanbeing's Avatar
Originally Posted by Tranberg View Post
If it uses the same large diameter (6.9 mm) Keihin jets as Sheng Wey, getting them will prove to be hard and expensive...
From fleabay UK . Just "Nickel plated" version of NORMAL jets
II (pz26) vs III (cpz26) http://wenku.baidu.com/view/24edb9fe...eaeaa31de.html
