Old 09-02-2007, 09:50 AM   #1
Savage   Savage is offline
Hi beam not working
Installed a new bulb and it's still not working - just the low beam. Anyone else had this problem?
Old 09-02-2007, 01:08 PM   #2
katoranger's Avatar
I had a bad ground wire in the headlight wire. Both Hi and lo would stop working until I jiggled the wires. I added another ground and it has been fine. If you have an ohm meter check to see if the wire is good in the headlight harness. Also see if you are getting any power to to the hi beam circuit.
A decent gigital multi-meter can be found at walmart for about $20.
Allen
Old 09-02-2007, 01:31 PM   #3
My stock bulb had one of the tabs broke on it so I assumed that was the problem. Put in the new bulb and it still didn't work. :(
Old 09-02-2007, 01:34 PM   #4
katoranger's Avatar
I would check to see if you are getting power to the hi beam side first. You can also check the new bulb with an ohm meter to make sure it is good, but I think it is a wiring problem.
Allen
Old 09-03-2007, 06:25 PM   #5
driller   driller is offline
Harbor freight runs a special on digital multi-meters for $3-4, I have one in each vehicle and in my son's boat. For light and trailer plugs they work great.
Old 09-03-2007, 07:24 PM   #6
Fixed it. I forgot that I hooked up aux lights to my hi beam quite awhile ago (they didn't work because of low to no power). The wire came undone. :oops:
Fixed it along with some solder this time.
Old 09-03-2007, 08:12 PM   #7
katoranger's Avatar
Good deal.
