Old 03-08-2016, 09:29 PM   #1
Coleguy   Coleguy is offline
Grin Bashan 250 Enduro has some speed!!
Hey guys just a little update. My bashan dual sport has hit just about 100 miles today, break in period has been good, no problems at all...well just one problem..at random times it does not want to shift or its hard to shift. Does not happen often but randomly just happens where I'll be stuck in a certain gear then it will allow me to change. Anyway today I got on a nice straight road that was slightly on a hill but to my surprise my bike hit 60 and I wasn't even wide open! On my gps it clocked at 57mph. I wasn't even in 5th gear yet I was in 4 and the bike wasn't screaming. I'm pretty excited because I'm using it mainly for street use but I haven't gave it a good hard go for speed yet . I see many people on the forum talk about lack of speed and or power and how their bike won't go past 50...I'm not sure why that is. Many people have the hawk but not many people on here have the Chinese bike I have. I wish more people had those! But yeah just checking in, let me know how your dual sports are doing with speed especially if you have the bashan 250 (not the storm model)
Old 03-08-2016, 09:56 PM   #2
Bone stock, You will find it hits the cieling (bogs, limiter?) At 61 to 63 using gps. Using speedo it says 67mph. Yes , it's a pretty stable platform and feels secure at higher speeds (was surprised too). I have exact model, just painted the hips
I have also plowed thru wild hog thrashed terrain which it sokes up quite well . It's light and you can throw it around with confidence. I am coming close to 300 miles in mine. Have found the transmission is breaking in smother - also tighten that clutch cable and cinch up those fork boots to the top to keep them clean. Enjoy
Ps 10 amp fuse under seat if starter stops working. Make sure the air box tube is connected to the carb. Don't need dirty air.
Old 03-08-2016, 10:18 PM   #3
PSS
Romex electric wire makes great tie straps.
Old 03-09-2016, 12:17 AM   #4
Attachment 4864
That's awesome! I haven't pushed this bike to the limit yet but as you said its pretty impressive for it being bone stock. I imagine we could get a little more speed after making a few upgrades and adjustments, such as carbs or sprocket setups. I am painting my hips black because I think the white on there is a bit ugly. Let me know what upgrades you do to yours and how the speed is going!
Old 03-09-2016, 12:38 PM   #5
BARLOW   BARLOW is offline
BARLOW's Avatar
i can not get my storm 250 over 55 in stock form in 5th gear wot if i lay down on the tank ... i hope if i get a set of jets or a new carb and jets it will help a lot ... if i get to 55 and give it any more throttle it slows down
Old 03-09-2016, 05:52 PM   #6
I made a high speed pass today wind at back. Made it to wot for a good min w/out bogging and an indicated 70 MPH before I backed out of it (indicated, should have had gps with me). It's singing, although I supposed to not be pushing it till after 500 miles seem to recall. Cool and damp conditions today.
Barlow, is your carb sealed to the airbox, mine was too short and had to make a intake extension with a 1 1/4 pvc coupler to make the seal.(used a heat gun to make it fit) Just checking.
Maybe the black paint on the rear covers was a nice performance addition too.
Old 03-12-2016, 09:38 PM   #7
jjn   jjn is offline
Where did you two get those bikes from?
Jon, in Keaau, Hawaii
Old 03-12-2016, 10:19 PM   #8
Jon mine was a West coast seller in San Francisco gokartsusa.com mine is the lesser option version of the bashan storm . Bashan blaze . There is even one on amazon (storm). Lightweight and mine runs like a champ. PS has a Lifan engine.
Old 03-12-2016, 11:24 PM   #9
jjn   jjn is offline
Thank you. I'll check these guys out.
Found it. Took a while, as they have it under "Apollo bikes".
Old 03-13-2016, 03:21 AM   #10
Yeah I don't know who put those websites together. They're just plain wrong.
Old 10-24-2017, 10:57 AM   #11
Onealb96   Onealb96 is offline
I’ve also got the 2015 Bashan Blaze 250 Enduro. I’ve got about 1000 miles on mine. Haven’t had too many issues. Main fuse blowing, battery dying, and I’m not a fan of having the key in it when you use the electric start. I’m having problems finding replacement plastics.
Old 10-24-2017, 11:07 AM   #12
Merlin   Merlin is offline
You can get a complete set of plastics for our bikes on Taobao for around $100 shipped.
Bashan Blaze
