Old 02-25-2016, 07:58 PM   #1
SeerAtlas   SeerAtlas is offline
Thumbs Up Hawk gearing
ok, somewhere on this board someone proposed taking 4 links out of the chain if going to a 45 tooth rear sprocket from the stock 50. i advise don't do it until you have your gears on and test the chain link yourself before removing any links. put a 16 front and 45 rear on my hawk today. needed to remove 2 links.
at indicated 55 in 5th, the bike now accelerates strongly on up my local steep road up the hill out of the valley, a long big grade hill where almost all cars/trucks downshift. :} not yet fully broken in, so don't have a flat out number for u yet, but i can tell u it will be impressive. this engine is strong and could easily pull a 17/45 combo, but the 16/45 seems sweet for the hilly terrain round here where u sometimes need a top of about 65-70 sustained to keep from getting run over,but yet the bike seems to have maintained its trail low speed grunt. hats off to Ricky Power Sports on bringing in such a capable machine!
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 02-25-2016, 08:26 PM   #2
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
I'm running 17/45 and haven't removed any links. I agree the engine is a torquey little bugger and pulls well . I love bike that you can short shift and the Hawk fis this role perfectly. Drop it into 5th about 30 and never shift for most road rides. I live in the Blue Ridge Mts so lots of ups and downs as well .
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 02-26-2016, 12:37 AM   #3
mjstef   mjstef is offline
I would love an extra gear so i could make 1st slower for mountain trails. I don't do much road riding as i have millions of acres of public land out my back door. Some of the trails are pretty rocky and steep though and on the really steep stuff i either try to get the tire spinning (HANG ON TIGHT!) or walk it and feather the clutch.......
Old 02-26-2016, 04:03 AM   #4
Hawk gearing
wolf, i,m in the ozarks
mjstep- i am at about 1k elevation, presume u r in the clouds. i think u can find a 14 or maybe even a 13 front counter shaft sprocket which should get your first gear down near honda trail 90 type speeds you must be riding some gnarly chit! :}
Old 03-15-2016, 09:27 PM   #5
Ron B   Ron B is offline
Ron B's Avatar
can any put the part # up for the 17 and 45tooth gears. or what bike to look for that fits
Old 03-15-2016, 09:51 PM   #6
newrider93   newrider93 is offline
newrider93's Avatar
I just ordered some. I bought them on Amazon. I was told to search JTF259.17 for front and I got a 43 tooth for the rear JTR269.43
Old 03-16-2016, 07:48 AM   #7
kohburn   kohburn is offline
kohburn's Avatar
17/43? what is your top speed with that combo?
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 03-16-2016, 12:51 PM   #8
newrider93's Avatar
Just ordered them so haven't put them on yet. Also going to be changing the tires from stock to more street tires
Old 03-16-2016, 02:17 PM   #9
kohburn's Avatar
ah, smaller od tire so need taller gearing
- 2016 CSC TT250
Old 03-18-2016, 10:44 AM   #10
kohburn's Avatar
while on this topic I toss some of the sprocket sizes I've seen into an excel spread sheet.
Front- Rear- Ratio
15 --- 45 --- 3.00
13 --- 39 --- 3.00
15 --- 43 --- 2.87
16 --- 45 --- 2.81
14 --- 39 --- 2.79
16 --- 43 --- 2.69
17 --- 45 --- 2.65
15 --- 39 --- 2.60
17 --- 43 --- 2.53
16 --- 39 --- 2.44
17 --- 39 --- 2.29
- 2016 CSC TT250
Old 03-18-2016, 11:16 AM   #11
Ron B's Avatar
I was thinking of going to a 44 rear with a 17 which would put it 2.59, just wondering if the bike would handle it.
File Type: jpg motorcycle-sprocket-drive-ratio-chart.jpg (55.5 KB, 1457 views)
Old 03-18-2016, 02:04 PM   #12
Thumbs Up
4 things to consider in answering that question: your topography, your altitude, your riding weight and your carburetor. my guess is yes. i am 250 or so, live in the hills, avg elevation here -around a thou, stock carb setup. I run a 16x45 on full knobbies and can pretty much go anywhere from gnarly trails to 65 + blasts down the local 4 lane. GO HAWK!!
I'll be VERY curious to see if my coming tt250 can match up.
Old 03-18-2016, 02:14 PM   #13
Ron B's Avatar
Well I decided not to chance it and just got on eBay and ordered the 1745 Combo. I hope it makes a difference decause with the stock gearing the RPMs are really screaming
Old 03-20-2016, 07:37 PM   #14
79elco   79elco is offline
17/43 combo
Any clearance problem with the 43t on the rear swing arm? Anyone running this combination yet?
Old 03-20-2016, 10:16 PM   #15
traygiddens   traygiddens is offline
just put the 17 on front and will put the 45 on later.
BUT, something which is a little concerning is there is a little bit of play in the front sprocket now , like the original was a little bit thicker than the aftermarket one. should this be a concern?
