Old 08-28-2007, 07:35 AM   #1
07buyang   07buyang is offline
automatic clutch adjustment
have a kids hunter style 110cc automatic. the clutch adjustment looks pretty standard. just loosen the nut around the adjustment screw turn in and then tighten the nut. the only problem is when you loosen the nut the thing pops out a half inch and no matter how much you turn in the screw, when you tighten the nut back up the screw winds up at the same adjustment you started with.... ANY IDEAS?????
i believe i have some pics if anyone wants to see the location
Old 09-06-2007, 11:46 PM   #2
Savage   Savage is offline
I think I understand but what's the problem with the quad? Why are you needing to adjust it?
Old 09-07-2007, 12:19 AM   #3
liverchip   liverchip is offline
Send a message via MSN to liverchip
Do you mean the center screw is popping out when you release the lock nut?....If so that doesn't sound normal. I have a 110. I'll check mine in the AM and post the results.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 09-07-2007, 12:20 AM   #4
Stupid question here. You're not removing the lock nut completly are you?
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 08-09-2019, 02:10 PM   #5
Tao125f1   Tao125f1 is offline
Sounds like it has a regular centrifugal clutch. if You can push atv forward with no resistance then it has a non adjustable clutch.
