Old 02-10-2016, 09:54 PM   #1
chuck   chuck is offline
taotao quantum
Hi
My scooter when I turn the key on nothing works.It kick starts fine and the lights and all work fine that way.Any suggestions will be appreciated.
Old 02-10-2016, 11:26 PM   #2
tortoise   tortoise is offline
There is typically a fuse near the battery for the low-amp side of the starter relay circuit.
Old 03-25-2016, 03:27 PM   #3
I checked that already,anything else that that I should check? Thanks for your help.
Old 03-25-2016, 05:09 PM   #4
Bruce's   Bruce's is offline
Check your battery .
Old 03-27-2016, 08:58 PM   #5
Thank you
Old 09-01-2016, 03:18 PM   #6
It was the fuse,physically it looked fine finally I tested it and it was burned.Thanks again for your help.
