Old 02-09-2016, 02:02 PM   #1
fishtime9   fishtime9 is offline
Hawk 250cc starter problems
I finally charged the battery today, but the starter does not seem to work? Basically, I press the yellow button and it won't engage, does someone know if i forgot something?
Old 02-09-2016, 03:00 PM   #2
Adjuster's Avatar
Key, neutral safety, clutch safety, brake safety, kick stand safety, kill switch?
Did you get it started yet?
My bike has a brake safety. Starter will not engage unless the hand brake or the foot brake is engaged.
Old 02-09-2016, 03:43 PM   #3
I tried all of them out. However, the starter will still not engage? Pherhaps, i might have to just measure the contacts and see if any volts are going through?
Old 02-09-2016, 03:59 PM   #4
Adjuster's Avatar
You should also be able to 'jump' the starter just to rule out a failed/broken starter motor.
Old 02-09-2016, 04:19 PM   #5
TXDSRIDER   TXDSRIDER is offline
TXDSRIDER's Avatar
I don't know your experience with motorcycles so I'm going to ask are you sure the red kill switch is in the right position. Also are you sure the battery is charged. On a side note can you kick start it. And check to make sure the spark plug boot is on solid. Also check the conection at the button to make sure it is solid.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
1987 Honda TRX 250R X2 one stock one modified
2002 Buell Blast
2001 Buell X1 Lightning
2000 Kawasaki ZR7
Old 02-09-2016, 09:28 PM   #6
BigDoug   BigDoug is offline
I have a Hawk that does not like to start when warm. I find a combination of clutch, wiggle gear shifter and start button generally works. Just make sure you can jump the starter first.
Old 02-10-2016, 06:36 PM   #7
I'll probably have a closer look this weekend.
Old 02-10-2016, 09:45 PM   #8
kohburn   kohburn is offline
kohburn's Avatar
did it start before the battery died? how long was the battery dead?
first thing i would do try jump starting it. a failed battery can show an ok voltage but have the voltage plummet as soon as a load is applied.
- 2008 Kawasaki Versys
- 2016 CSC TT250
