Old 01-29-2016, 07:01 PM   #1
Torgo   Torgo is offline
Torgo's Avatar
Hawk Valve Clearance
I saw this on the TT250 thread and thought I'd copy this here, since for all intents and purposes, it's identical for the Hawk. I just did this myself last weekend and couldn't summarize the steps any better:
http://californiascooterco.com/blog/?p=19832
I would suggest skipping the seat and gas tank removal on the Hawk. There's enough clearance after removing the front trim pieces to access and remove the valve cover as well as get to the gaps themselves.
I remember that someone else posted here that there was no valve clearance at all on his Hawk when he first opened it up - same for mine. Had to loosen and back off the adjuster to create it. Now it sounds like it should - got that soft, light clicking going on.
The article does a nice job explaining why too little gap is bad thing over time, so if these are shipping here with no gap to start, it's a good thing to check during break-in. It's recommended in the first round of maintenance in the owner's manual. Since CSC put together a really nice write-up for pretty much any 229cc engine, that helps to make it a pretty easy thing to check during that first oil change. It's a 30 minute to an hour job tops.
Old 02-01-2016, 11:17 AM   #2
lanceallenr   lanceallenr is offline
Thanks Torgo,
After reading your post I decided to check my valve clearances. I ended up having zero clearance on both valves. I set mine to 3 thou of an inch (3 thou = 0.0762 mm) a tad outside of recommend my feeler gauges are in thou and couldnt decide 2 thou or 3 thou. After reading the article and what it said about wear make me go with 3 thou.
After performing the adjustment my bike started up with no choke and felt like it had more top end power. I put on 20 miles on the bike and plan to recheck before I ride it again. Before the adjustment it was making no valve ticking noise. Now after the adjustment it was making valve ticking noise.
Old 02-01-2016, 02:31 PM   #3
Slappy valves are happy valves. Keep up the good work. Other than frequently changing the engine oil, the best thing you can do to prolong the life of your engine is to maintain the proper valve lash.
Old 02-01-2016, 03:43 PM   #4
fitze   fitze is offline
If I remember, the RPS Hawk valve lash is 0.05mm
Old 02-01-2016, 06:13 PM   #5
On the CG type (pushrod) motors I've been using .05 on the intake and .08 on the exhaust. Seems to work out ok. I'd imagine the exhaust valve runs hotter causing more expansion, would be my guess. Saw this online somewhere.....probably here! LOL!
Old 02-01-2016, 07:09 PM   #6
Mudflap   Mudflap is offline
On all 3 CG type engines I own, the lash grows as the engine gets warmer. They may not all be that way but I suspect they are.
Old 02-02-2016, 10:30 AM   #7
Makes perfect sense. I'll try to remember to set the exhaust a little on the looser side next time.
Old 05-22-2016, 10:33 PM   #8
xposur   xposur is offline
I just checked my clearance...
my exhaust side was gliding snugly with .002 inch(.051mm)
and the intake side was a little more loose with barely any friction on the .002 inch
Old 05-23-2016, 12:11 AM   #9
Johnp   Johnp is offline
Johnp's Avatar
I just did mine yesterday. From the factory it came with ZERO. It was extremely tight... Took about 45 minutes to do it the first time. Probably take 15 next time now that I've done it once.
John P.
2016 Hawk 250 - Black
All my mods are documented on my Blog!
My Blog | Google+ | Twitter | Facebook
Old 05-23-2016, 11:02 AM   #10
Sport Rider's Avatar
good for you!!! it WILL be easier the next time. I had the tank off while putting the new digital speedo on and decided to go ahead and check them. I had one loose (probably my fault on the last adjustment). it really took me more time to get the feeler gauges and such out than to actually do the adjustment.
Old 09-02-2016, 08:53 PM   #11
Republic   Republic is offline
Checked my clearance today, only about 15 miles on the bike so far and I had zero clearance. I adjusted them to .07 per the CSC guide and I think I overdid it because now its very loud, but it started easier than it ever has. I've lost my daylight so I'll start again tomorrow.
On the drag, should I be able to push the feeler without it bending? Or should I just be able slide it in like a knife and pull it out?
Old 09-02-2016, 10:44 PM   #12
Ariel Red Hunter's Avatar
I loosen the valve adjuster, slide the feeler guage all the way in, tighten the adjuster to where you can pull the feeler guage part way out, with 2 or 3 pounds of effort. Then tighten the lock nut, and see if it pulls out with the same pressure. Often, until you get the hang of doing this, the locknut tightens the valve to where it takes real effort to get the feeler guage out. So, guess what. You get to do it over again. A couple of times, and you'll know how to do this.
Old 09-03-2016, 06:24 AM   #13
jimwildman   jimwildman is offline
jimwildman's Avatar
agreed, if the feeler guage just slips right out with no drag at all, your gap islikely bigger than .07.
ive heard alot of figures on the amt of lash needed, mine are set to .05.
its not loud at all.
anything is better than .00
Old 09-03-2016, 07:06 AM   #14
As much as I had to turn that adjustment screw, I wonder if my valves were even closing all the way. Thank goodness I read this and checked them ASAP or I KNOW I would have ended up with burnt valves.
Old 09-03-2016, 07:46 AM   #15
Probably would not have burned the valves because on these engines the valve lash increases as the engine warms up.
