Getting a Hawk Running Properly
Hey all! I have completed assembly on my hawk and did the initial firing up. after tinkering with the idle screw a bit I got it to idle after taking it off the choke. now the real fun begins.... NOT! as I told you all when I joined, carbs are a mystery to me. it appears that I'm going to have to peel back the curtain and learn a few things.
Here are the symptoms of how it is running now. it starts after warm with a small twist of the throttle, but not using choke at all. idles fine. revs ok when sitting still. taking it out on the street, it will speed up, but revs don't come all that much and it starts sputtering and losing power. what's the next steps in troubleshooting and correcting? ![]() ![]() ![]() |
The stock carb is a little clunky, but it should run OK after it warms up. First of all, what exactly are you doing with the choke? How are you setting it?
There are three positions for the butterfly valve: open (bottom), half (middle), and closed (up). When it's cold out, I have to close it (up) to start. I let it warm up before I drop it down to half, and then fully open it. You only want to operate it when it's at temperature at the open setting (bottom). So hopefully you're stepping through that similarly. Also, it will not idle by itself as it warms up. After it starts, I have to hold the throttle open a bit. After it warms up a bit, about the same time I start to open the carb, I can then tighten up the idle screw and it'll start idling. Once it's fully warmed up, I'll back the idle off until it idles at what I think is a good RPM. If you turn it too low, it'll kill it, but it doesn't have to be that accurate - you just want a reasonable idle that keeps the engine spinning when you have to stop. The one nice thing about the stock carb is that the idle adjustment screw is easy to adjust by hand. So you'll figure out how to add and back off the idle after a little bit. Hope that's a little bit of help - you may not be maximizing the performance with the stock carb, but I've found it to be OK once I got a better feel for its quirks. |
#3 | |
the other thing I am noticing is how it comes off idle. it seems to be lagging at the rpms coming back down. I'm familiar with that as perhaps an air leak, so perhaps I'll check the boots to be sure they are good and tight. open to other thoughts/ideas though! thanks!!! |
Have you checked the valve clearances?
jb
2016 Honda CB500F......2017 Triumph Street Twin 2014 XT 250........ |
I am unfamiliar with the carburetor on your motorcycle. However, you do need to adjust the pilot mixture screw (PMS), if you want you bike to idle properly. You should not need to fiddle with the idle speed screw if you have properly adjusted the pilot mixture screw (PMS).
This was my experience as well!!! I installed an ebay mikuni, replaced the jets along with a 17T front sprocket and it is a totally different machine. I suspect that the stock carb is jetted very lean to meet emissions.
The stock carb could likely be rejetted as well, but will require drilling out the tamper resistant screws that hold on the carb bottom bowl., but would be $40 cheaper than the mikuni. |
#7 | |
#8 | |
Swapping or re-jetting is not that difficult, you'll be much happier when you do. Someone here sourced the jets to fit the stock carb, but I can't recall specifics...or many have done the mikuni swap and were very satisfied. |
#9 | |
![]() Quote:
#10 | |
As the others stated, you certainly do need to adjust the carburetor on every bike, and that usually involves changing the jets. However, you shoudl always adjust the pilot mixture screw (PMS) before you change the jets.
![]() Quote:
Even if you decide to switch to a Mikuni carb, I strongly suggest you still make your first adjustment to the pilot mixture screw. ![]()
#11 |
Take it to Carolina Fun Machines in Matthews NC. The dealer application says they have to fix it.
Ask Adam Sport Rider, if you put on a new carb you lose warranty. |
#12 | |
#13 |
I worked on several different types of dirtbikes, as well as motorcycles in general. However, it is important that you always adjust the pilot screw by screwing it in 1 1/2 turns and than either increase or decrease it, depending on the way the bike idles while its running. But I also read on the forum that these chinese bikes are known to have bad carburetors, in which you would have to get a new one such as the "mikuni" or "qlink" from e-bay. I would highly suggest to just stick with a clone, due to the fact that they are way extremely cheap and do the same good job. Also make sure to clean out the carburetor before installing it! A little clean with the carburetor or break pad cleaner will definitely improve your performance, as well as you never know when manufacturers left medal pieces or debris in there. Please don't hesitate to contact me throughout pm's, if you have any further questions regarding your hawk.
#14 |
got it running again today and took it for a spin around the block just to try it out. definitely starving for fuel from the way it's running. just wont rev without sputtering. went ahead and ordered a new carb off ebay. will put jets in before I install it. gotta get the jets for it too. will be easier in the long run, I expect.
#15 |
I ordered this carb for the Hawk:
http://www.ebay.com/itm/360100626734...%3AMEBIDX%3AIT Can someone tell me which jets I should order from here? http://www.pjmotorsports.com/mikuni-jets.html |
