Old 12-30-2015, 02:05 AM   #1
justinope   justinope is offline
Actual seat height for RX3?
I was doing some more research on the bike and it looks like the last question i have is what the actual seat height is. A lot of sources seem to quote 31.3" but that was when there was a 15" wheel still coming standard. Now with the standard 17" rear, I'm wondering if the seat height has gone up much higher. Also curious how much more a 19" front would raise it.
I'm very close to pre-ordering a 2016, but just making sure I'm 100% sure what I'm getting into.
Old 12-30-2015, 08:06 AM   #2
CSaddict   CSaddict is offline
CSaddict's Avatar
Also interested in this info as I haven't decided to buy yet.
Old 12-30-2015, 09:59 AM   #3
CSCDude   CSCDude is offline
CSCDude's Avatar
The seat height is 31.3 inches. The 17-inch rear wheel and tire is actually very slightly smaller in diameter than the Asian-configuration 15-inch diameter wheel and tire due to the 17-inch rear tire's smaller sidewall.
Joe
www.ExhaustNotes.us
Old 12-30-2015, 01:56 PM   #4
thanks!
Old 12-30-2015, 05:41 PM   #5
jbfla   jbfla is offline
I measured the seat height on my RX3 with a level across the seat at its lowest point.
It was 32".
jb
2014 XT 250........
Old 12-30-2015, 06:29 PM   #6
It was 32".
jb
I didn't reply earlier because I knew someone had actually measured the saddle height. Thanks for checking in, JB.
Old 12-31-2015, 02:40 PM   #7
That was the seat height on my stock RX3.
I have installed a lowering link, but haven't measured the actual new height.
I'm away from home for the holidays. Will be able to measure again next week.
The rider "sag" is only 3/4" (180#). I think I need to play with the rear shock preload when I have the bike apart for the valve check. That may affect the seat height.
jb
2014 XT 250........
Old 12-31-2015, 02:50 PM   #8
I haven't measured the saddle height on my bike, because it doesn't cause me any problems. After you adjust the spring preload on the shock, it will affect saddle height.
I think someone else here has measured the saddle height, both with the stock saddle, and one of the aftermarket saddles.
Old 02-04-2016, 12:01 PM   #9
I had the opportunity to remeasure the seat height with the lowering link installed:
jb
2014 XT 250........
Old 02-07-2016, 07:17 PM   #10
Dualsport Chic   Dualsport Chic is offline
Dualsport Chic's Avatar
Seat Concepts Narrow Seat
Does anyone have any experience with how much additional reach would be provided with the Seat Concepts Narrow seat? Ordered one and I have a 29" inseam - hoping it will do the trick as 32" standard will be tough for me to get the balls of my feet down.
Old 02-07-2016, 07:26 PM   #11
I have a TMEC 200 and my seat is 33.5". I am 5'7" and about 30" inseam, and can get both feet down, although not completely flat-footed. Granted the CSC bike might be a little larger, but I am guessing the RX3 will be fine for you.
Old 02-07-2016, 08:24 PM   #12
Jay In Milpitas's Avatar
Originally Posted by Dualsport Chic View Post
Does anyone have any experience with how much additional reach would be provided with the Seat Concepts Narrow seat? Ordered one and I have a 29" inseam - hoping it will do the trick as 32" standard will be touch for me to get the balls of my feet down.
Paging Woodlandsprite, please pick up the white courtesy phone.
I think she may have some good input for you, Dualsport.
Old 02-07-2016, 08:33 PM   #13
Thank you Jay - Woodland Sprite is a former TWF (TwoWheelFemales) member - we were on the forum together for several years prior to it shutting down this past summer. Will be great to get her impressions of the bike!
Old 02-07-2016, 09:49 PM   #14
I have/had the narrow seat (it is currently back at CSC being re-covered).
I didn't find it any lower than the stock seat...but maybe more comfortable....but they have had it so long, I have forgotten what it felt like.
jb
2014 XT 250........
Old 02-07-2016, 10:51 PM   #15
marzhere   marzhere is offline
Not sure the narrow seat will help much. Detours has one and he was kind enough to let me test sit on his motorcycle. I didn't notice much if any difference. I have the lowering link, a shaved down stock seat, and a 29" inseam...can barely get the balls of my feet on the ground.
Our collection:
Mark - KLR650, TT250, RX3
Marlissa - RX3, XR100
