Adjusting Shifter position
So...I got myself some new boots but the toebox is taller than my current boots - went out for a ride to check the clearances on the controls and I think I might want to move my shift level up a hair to accomodate - with the current settings, its an extremely tight fit to get my toe under the lever - not an ideal situation. Is changing the shift lever position as simple as loosening the locking bolt, adjusting the position and tightening the bolt back down? It looks like it's just clamped in place using that bolt...
Also, I imagine I need to be wary of moving the lever too far up... |
Yes ! Just remove the bolt ,pull off the lever ,reposition it ,and reinstall the bolt .Easy !
That's it. Be sure to just move one notch at a time. It will go farther than you think.
#4 | |
Since I wear either a men's 12W or 13R, I've learned how to adapt over the decades. |
I have found that if I can easily get the toe of my boot under the shift lever that I have to lift my boot off the foot peg to down shift. By watching how I shift I see that I shift with the side of the toe box and the welt of the boot. YRMV
Dan CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650 |
If you need more room for you boots, install a shift lever designed for the Honda XR650L.
Thanks again Spud .. and I see shift lever is listed in the compatible parts list
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp, |
Sprite, take the time to mark the shaft before you remove the shifter, so you know where it started from. A dab of liquid paper (or even nail polish?) will do the trick. I make a mark on the shaft, right at the gap in the shifter.
#9 | |
![]() The folding tip on the XR650L shift lever will help to prevent damage to the engine, as well as the shift lever, in case of an impact. The stock, Honda shift lever, or any of the aftermarket shift levers will fit. I have the spare MSR shift lever because I prefer having the Emgo 83-88068 model fitted on my Honda XR650L. ![]() http://www.amazon.com/1993-2004-Hond.../dp/B0055DN0UE ![]() Here is a photograph of the Emgo shift lever mounted on a Husqvarna motorcycle. ![]() ![]()
#10 | |
#11 |
Swapped out the shifter to the Emgo version - which is the same dimensions as the stock shifter, no longer, no shorter. The notch position on the attachment is different, so not sure how much I wound up moving the shifter relative to the footpeg. I now can get my toe under the shifter, but if I want to downshift multiple gears I have to conciously pick my foot up to get the subsequent gear shifts to occur. Haven't decided what I think of that.
#12 |
If you don't like it ,move it up or down a notch until you find where it works for you .
#13 | |
#14 |
At the very least, you can clean off the old nail polish mark, and mark the position of the new shifter. That'll help you control the adjustments, one spline at a time.
#15 | |
