Old 12-08-2015, 08:52 PM   #1
detours   detours is offline
detours's Avatar
A pop, a rattle and a surprise!
I was on a ride last week when I heard a pop and a rattle in the engine. I wasn't far from home, so I turned around and parked the. When I found time to pull things apart, I figured out what happened.
On the intake valve side, the adjuster locknut had come loose. Worse, the foot at the bottom of the valve adjuster had broken off and both of them were bouncing around under the valve cover!
Luckily I was able to fish them both out with a magnet and there doesn't seem to be any other damage.
Apparently, I didn't tighten the locknut enough during my last valve job and it worked itself loose. Then the adjuster backed itself out far enough to pop the foot off.
Red 5 standing by!
2014 Ural Patrol
Old 12-08-2015, 09:04 PM   #2
detours's Avatar
Anyway, I called Gerry today and asked him how to repair it. I was worried I might have to remove the engine and take off the top end to take off the valve rocker ... which kind of scares me!
Luckily, he tried out a few ideas on his bench engine and gave me a workaround.
The valve adjuster is actually two parts: a threaded bolt and a foot, which fit together like a ball and socket. Gerry is going to send me the adjustment screw and foot separated (at no charge ... thanks CSC!). I'll screw in the adjuster and hold the foot in place until it pops in. Then I'll adjust the valves like normal, and I'll be back on the road.
Red 5 standing by!
2014 Ural Patrol
Old 12-08-2015, 11:47 PM   #3
Thanks for posting the warning, amigo. We should always make sure to tighten the nut on the valve tappet. I'm glad your engine didn't sustain any more damage.
Also, thanks for letting us know about the design of the tappet, and the usual, excellent customer service from CSC.
Old 12-08-2015, 11:57 PM   #4
Jay In Milpitas's Avatar
Good info Detours, thanks for sharing.
Old 12-09-2015, 01:10 AM   #5
CSC has earned every future sale with awesome service like that!
Old 12-09-2015, 01:59 AM   #6
detours's Avatar
Yeah, definitely double-check the lock nut. I'm sure I tightened it, but obviously not enough.
CSC offers really great service. Gerry spent time on the phone with me making sure he understood the exact issue. Then we texted lots of pics back and forth and he gave me the procedure and then talked me through it on the phone to make sure everything was clear.
It's a rare shop that cares whether you understand the issue and how to fix it ... then send the part for free even though it was most likely my fault.
Red 5 standing by!
2014 Ural Patrol
Old 12-09-2015, 07:12 AM   #7
Amen on all points, mate.
Old 12-09-2015, 08:09 AM   #8
keithmaine's Avatar
Sorry that happened to you glad it all worked out. And it is always good to hear of CSC customer service coming thru time after time.
Old 12-09-2015, 08:43 AM   #9
Lee R   Lee R is offline
Lee R's Avatar
Thanks for sharing detours, all of us will probably tighten than locknut a bit more next check!
Old 12-09-2015, 08:54 AM   #10
keithmaine's Avatar
On my Ural I change the nuts to a self locking nuts as a precaution because guys had nuts back off also. Maybe the same is doable on the RX3
Old 12-09-2015, 09:19 AM   #11
3banger   3banger is offline
3banger's Avatar
Thanks for the update. Glad more damage wasn't done! That part could have bounced down the cam chain path and done a lot more damage. If the lock nut came looses its likely the adjuster backed off until the ball/foot could turned sideways and get knocked off its ball mount. And another fine example of CSC's excellent customer service!
Also this I the first issue I've seen posted to any forum about any internal engine issue at all with the RX3! Well this and my clutch but that was all my fault and at some level a clutch is a wear item.
Old 12-09-2015, 09:31 AM   #12
DanKearney   DanKearney is offline
Thanks for that heads-up.
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 12-09-2015, 10:18 AM   #13
3banger's Avatar
Detours, how many miles since your last valve adjustment?
Old 12-09-2015, 11:13 AM   #14
Excellent tip! What type of locking nuts did you use on the Ural? I've thought about that in the past, but wondered if the nylon in a typical Nyloc nut might melt. I also considered a distressed thread nut, like you find in automotive applications. I'm very curious about what worked for you.
Old 12-09-2015, 01:22 PM   #15
keithmaine's Avatar
they are nylon and they do not melt, melting point of nylon is in the area of 470F. The Ural is air cooled and the head temps are from 275f-325f. I would assume that the RX3 would be slightly cooler.
I believe they were these
McMasterCarr 90576A116
Zinc-Plated Class 8 Steel Nylon-Insert Locknut, M8x1 Thread Size, 13mm Wide, 8mm High
