Old 12-08-2015, 06:37 PM   #1
TXDSRIDER   TXDSRIDER is offline
TXDSRIDER's Avatar
Transmission issues already.
So my hawk has 300 miles on it yesterday I changed the oil so I could put in my magnetic drain plug everything went well oil looked good nothing in the screen. Put the same oil I had been using from day 1 rotella t5 15w40. Took the bike out everything seemed fine then when I went to stop I noticed I couldn't get into neutral which had never really been a problem. A while later it didn't seem to want up shift every time. I blamed it on the boots I was wearing that I had never riden in. I soon noticed I wasn't missing the shifter it just wasn't pulling up. So I parked the bike and waited until today to adjust the clutch cable. Took some slack out and it seemed better except neutral, I could only get it in neutral if the bike was off. Messed with the cable a little more and started to have some success with neutral but when I went out I was having a hard time up shifting especially past second as of my last ride I couldn't come past 2nd so I parked the bike before I did any more possible damage. Any ideas I'm still not sure if my cable is 100% adjusted right but it doesn't seem any different than before the oil change.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
1987 Honda TRX 250R X2 one stock one modified
2002 Buell Blast
2001 Buell X1 Lightning
2000 Kawasaki ZR7
Old 12-08-2015, 08:33 PM   #2
Check to see if the shift lever is loose. You might also want to tilt the lever downward a notch or so.
Old 12-09-2015, 02:42 PM   #3
TXDSRIDER's Avatar
So the shifter was tight and I moved it down a couple notches but I belive the problem is much more severe. After I re tightened the shifter with the bike off I tried cycling the gears the shifter has a hard stop trying to go above second it just stops you physically can not put it in 3rd. Except my be if I hit it with a hammer lol. I guess it could be a shift fork but at 300 miles. And I don't beat on the transmission. Of course my fake 90 day warranty just ran out too. Any ideas on the next step obviously opening things up is going to need to happen but could something just be loose or out of alignment. I knew I was going to need to tinker but this seems a little excessive for 300 miles.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
2002 Buell Blast
2000 Kawasaki ZR7
Old 12-09-2015, 04:19 PM   #4
The next easiest thing to do is check the shift pawl. To do this you must drain the engine oil, and remove the right crankcase cover. The shift pawl is located at the bottom rear of the engine, behind the clutch basket. It will look similar to the shift pawl shown inside the red oval of the photograph below.
Starting at the 8:30 mark, the following video shows how the shift pawl operates the transmission. Work the shift lever and inspect the shift pawl for proper operation.
Old 12-09-2015, 08:10 PM   #5
TXDSRIDER's Avatar
Thanks spud. I was about to remove the case but wanted to wait for your advice. I put the bike up on the stand and was rocking the wheel back and forth while shifting and got it to cycle all the gears multiple times. Took it out for a ride went 10 miles around the block a bunch of times no problems. Still seems a little harder to put in neutral than before the oil change but I can live with that I really only go in neutral if I'm parking the bike. Hopefully it was just a fluke.
On a side note I'm going to measure that led heat sink for you tomorrow when I bleed the chinese fluid from the front brakes.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
2002 Buell Blast
2000 Kawasaki ZR7
Old 12-09-2015, 09:12 PM   #6
Silly question but is your idle set really high? That can make it difficult to find neutral as well.
Old 12-09-2015, 09:35 PM   #7
SlowJunk   SlowJunk is offline
Mine does not shift up from 2nd (to 3rd, etc...) if it is not moving (i.e. rear wheel turning). If I recall correctly that is the correct behavior as described by the manual.
I have found that after some run in (about 200 miles) finding neutral is much easier. I had to adjust (tighten) the shift cable at the engine. Then needed a few rides with the engine hot to set the correct shift cable tension at the handlebar shift lever. In addition, I made sure that the shift cable was not moving about where is fastened by the rubber band at the down tube. This was to make sure that the cable was not moving around the down tube to get near the exhaust pipe and heating up.
Old 12-09-2015, 09:48 PM   #8
TXDSRIDER's Avatar
No my idle is honestly a little low. If I give it a little gas while shifting into neutral it goes right in or if I shift to neutral while still rolling.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
2002 Buell Blast
2000 Kawasaki ZR7
Old 12-09-2015, 09:50 PM   #9
TXDSRIDER's Avatar
I had read that a lot of older honda motors don't like to cycle gears when stopped. That is why I tried rocking the wheel and that worked.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
2002 Buell Blast
2000 Kawasaki ZR7
Old 12-09-2015, 09:54 PM   #10
TXDSRIDER's Avatar
I really think it had something to do with riding in my motocross boots and maybe botching a shift or two and maybe something got out of alignment or bound up. When I went for my successful ride I was back in my sneakers. Fingers crossed it was a one time event. But now I feel like I wasted my money on new boots because I'm afraid to ride in them lol.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
2002 Buell Blast
2000 Kawasaki ZR7
Old 12-09-2015, 10:23 PM   #11
I feel your pain, I have a set of Alpinestar Scouts that I bought online, tiny bit narrow but I couldn't return them so I'm stuck with them, lol. Anyways, I can't shift for beans when I'm wearing those boots. They are stiff enough that they take the action out of your ankle and require you to use your leg instead to shift... Some people say you get used to that but I haven't managed to yet!
Old 12-10-2015, 12:21 AM   #12
jct842   jct842 is offline
You might try putting a plastic bag in each boot, fill water and freeze. Will probably stretch boot enough when the water expands to ice.
Old 12-10-2015, 09:14 AM   #13
Cyborg   Cyborg is offline
transmission issues already
the shifting (no shift) when at a standstill usually means the clutch is not fully open and is slightly dragging ,,i've had that on a few bikes,,on a new machine it means (most times) the cable has simply stretched ,,,
Old 12-10-2015, 09:56 AM   #14
wilserchinarider   wilserchinarider is offline
Does the bike shift up through the gears at 10-20-30-40 MPH? I wouldn't expect a bike like this to shift effortlessly through the gears on the kick stand??? Wheel speed, engine speed and transmission like to be synchronized for nice easy butter shifts? At only 300 miles I might expect the transmission to still be a little stiff...
At speed my bike will effortlessly go through the gears, even without using the clutch....cant do that on the kick stand in the garage!
Old 12-14-2015, 01:16 AM   #15
TXDSRIDER's Avatar
I was having the problem when moving also but after I rocked the wheel and cycled the gears on the stand (and put on my regular shoes) the problem has been non existent in 50 miles of neighborhood style driving so hundreds of full cycles of the gear box.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
2002 Buell Blast
2000 Kawasaki ZR7
