Old 12-02-2015, 12:51 PM   #1
rjmorel   rjmorel is offline
rjmorel's Avatar
CSC Quick Change Oil Kit
Redhawk: "CSC is offering a "quick oil change" kit. I'm guessing that it gets installed in place of the magnetic plug; is this right?"
Spud: "No, I think the oil change kit includes oil, an oil filter, an oil pan, a funnel, and a socket wrench."
Spud I think Redhawk is talking about this new item that uses a spring loaded valve thingy, rj
http://www.cscmotorcycles.com/QUICK-...p/csc-3002.htm
Live Zong, and Prosper
Old 12-02-2015, 01:01 PM   #2
keithmaine's Avatar
Looks cleaner, but quicker ???
Old 12-02-2015, 01:05 PM   #3
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
RJ, yes, this is the item I was referring to. I asked about it today while I was ordering my red TT. It goes in the drain plug hole. Apparently CSC changed the plug size after the first shipment to a larger size - no problem, CSC knows which size you need.
Dan
Old 12-02-2015, 02:05 PM   #4
keithmaine's Avatar
I would like to see it in action
Old 12-02-2015, 06:35 PM   #5
Okay. I looked under accessories>hardware and tools. I found the regular, oil change kit, but not the quick change kit. Thanks for letting me know.
http://www.cscmotorcycles.com/HARDWA...OOLS-s/185.htm
Old 12-03-2015, 01:49 AM   #6
detours   detours is offline
detours's Avatar
I had a similar device on my car a few years ago. I suppose it was a little quicker because you just screw the hose onto the valve plug to drain it. But mostly it's just a cleaner way to drain the oil. The brass cap keeps the spring valve clean and protects from any damage.
Red 5 standing by!
2014 Ural Patrol
Old 12-03-2015, 03:40 AM   #7
rjmorel's Avatar
2 thoughts good and bad about this quick coupler drain plug.
1) once installed it would protect the threads in your engine case from wearing out or being cross threaded when changing oil.
2) wonder if it hangs down more then the standard oil drain plug and if there is a danger of it getting bashed when going over a rock? Too cold to go out and look at my RX3 so these 2 cents are just bouncing around in my head, rj
Old 12-03-2015, 04:18 AM   #8
2 thoughts good and bad about this quick coupler drain plug...
...wonder if it hangs down more then the standard oil drain plug and if there is a danger of it getting bashed when going over a rock? Too cold to go out and look at my RX3 so these 2 cents are just bouncing around in my head, rj
I'm with you; it's too cold to check my RX3. However, I think the skid plate will protect the quick coupler.
Old 12-03-2015, 04:23 AM   #9
I'm not trying to be negative, but I think it is faster, and cleaner, to drain the gearbox first with the oil screen plug on the left side of the bike. This plug is ideally located to quickly and cleanly drain most of the oil from the gearbox reservoir. Then, after most of the oil is drained from the gearbox, removing the magnetic plug can't make much of a mess.
Old 01-16-2016, 07:47 PM   #10
CSC posted a description and tutorial of the RX3 Quick Oil Change Kit at the CSC Blog.
http://californiascooterco.com/blog/?p=19612
Here is the video which accompanies the article.
Old 01-17-2016, 09:13 AM   #11
keithmaine's Avatar
I said that I would like to see it in action, in my December post. I guess someone is listening.
Old 01-17-2016, 05:42 PM   #12
CSC is always listening; their customer service is superb.
Old 01-17-2016, 06:41 PM   #13
keithmaine's Avatar
That they are, Sara contacted me said she was sending out my center stand too.
Old 01-17-2016, 07:20 PM   #14
rjmorel's Avatar
Kiethmaine, will this be the new center stand with the magic lever to make it easier to get it up on the stand? Pics and a report pretty please. rj
Old 01-17-2016, 07:49 PM   #15
keithmaine's Avatar
Yes it is, I will post pics and review
