Banned
stock handlebars ID and Bar ends/throttle locks
Thoughts:
Wish the stock RX3 grips were a bit longer Would like to install bar ends to provide a bit longer bar Also want a throttle lock Have used a Throttlemeister setup on my SV650 for years. As far as bar ends, Spud-do you know the stock bar's ID? Anyone have a throttlelock they like working with stock grips, etc? |
#2 | |
http://www.protaper.com/default/cont...andlebars.html |
The inside diameter of the stock handlebars is very small, about 12 mm. In fact, I tapped the inside diameter of the stock handlebars for a 1/2-inch thread when I installed my Tusk D-Flex handguards.
http://www.chinariders.net/showthrea...ht=tusk+d-flex ![]() I think Jay has offered a good suggestion for you to consider aftermarket handlebars. ![]() ![]() https://www.rockymountainatvmc.com/p...lebars+1+1%2F8 ![]()
Banned
Thanks for the info guys. I'm happy with the stock bars, and if the ID is THAT small Spud, I may look at my spare set of Throttlemeisters that use an expansion plug and mod them
Stock bars on mine were roughly 1/2" inside. I put a 1/2" drill in the ends to make them round for my hand guard expanding mounts (turned down from 5/8") and the drill hardly removed much material. Spud was able to tap his with a 1/2" tap so his may of been a slightly smaller diameter inside to get enough thread for the bolt to grab ?????
rj
Live Zong, and Prosper |
I definitely got enough thread for the 1/2-inch bolt to grab securely.
I think the rx3 bar is narrow indeed..
One good alternative is a wider, re-inforced bar, similar to the Kawasaki KLE 500cc one. |
#8 | |
![]() Works well and the install looks clean. Cheers, Dan K.
Dan Kearney - Black Hawk, Colorado, USA ![]() Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ." |
Banned
Already wish the grips were longer...doesn't the Vista take up room on the grip?
#10 | |
Banned
Again, I like the stock bares rise and bend. |
#11 | |
You might also consider using an appropriately sized O-ring placed between the inside edge of the rubber grip and the instrument switch cluster. I used this method on my Urals and Yamaha previously. If you get the right sized O-ring, it will exert enough friction to hold the throttle open for 5 or 10 seconds before slowly closing. Enough time to shake out your hand, adjust mirror, etc. And it takes up zero grip space. Cheers, Dan K.
