Old 11-27-2015, 01:43 PM   #1
Co2   Co2 is offline
How To Changing Gear Sensor ( Stuck ) NC250/ZS177
Solving methode for, stuck screw, gear sensor replacement/changing.
Materials :
1. Toilet paper (most important mateial no:1 )
2. Screwdiver (flat)
3. Old metal/wood handle knife
4. Gas / fire cooker
5. Maull / mallet
Gear sensor of nc250/zs177 plastic/abs or idk. , simple cuted with hot metal prensibe ^^
1 . Old knife on cooker stovve on gas fire, heat/roast bit red color is ok. (need 2-3 time)
2. Surgey with laser blade ^^ (use a towel, work safety every time no:1 )
3. Cut it ok, remove need a FLAT screwdiver (gear sensor has O-Ring
4. Most important material life saver, toilet paper on action ^^ (happy sealing hole's ^^ , hygiene rules.. )
Mallet helped screw side impact for opened easy(stuck problem of screw.)
5. Old/original has 6. pin (1 neutral) 5. gear, new is ours RX3 sensor. mounted.
Old 11-27-2015, 02:04 PM   #2
Thanks for sharing the great photos.
Why did you change the gear indicator? Did you switch from a 5-speed to a 6-speed transmission when you worked on your engine?
Old 11-27-2015, 02:09 PM   #3
Co2   Co2 is offline
Moto has now 6.gear and ours RX3 sensor have 7 pin 7 contact surface in. 1 neutral 6 gear, 6+1 indictor on my speed screen fabricated has 6. gear indicator but sensor 5, now correct 6.th.
Old 11-27-2015, 02:41 PM   #4
Yes, I remember your engine rebuild project. However, I didn't know you did it just to get the 6-speed transmission.
Old 11-29-2015, 01:50 PM   #5
Co2   Co2 is offline
Worked sensor 6th. indicator active now, idk maybe all gear sensor of rx3/nc250's same.
Colours
Dominant color / Little line color
Neutral : Light Blue / Red
1. Gear : Pink (1 color)
2. Gear : Dark Blue / Red
3. Gear : Green / Black
4. Gear : Yellow / Red
5 .Gear : Yellow (1 color)
6. Gear : White / Blue
Speedometer/tachometer different, only for RX3 spare gear sensor colors and gears.
Happy end for gear sensor.
Old 11-29-2015, 04:00 PM   #6
The wiring colors for your dirt bike are very similar, but not exactly the same as those specified by the Colombian Owner's Manual for the AKT Adventour 250.
http://www.chinariders.net/showpost....3&postcount=20
