Old 11-22-2015, 01:47 PM   #1
Co2   Co2 is offline
Canceled start procedure ( brake+start button cancelled.)
Standart procedure for start moto, key open + neutral gear offcourse + killswitch open + pull brake lever(front or rear ) + push start trigger or button and run.
Need help changed this procedure, i want how i can do , cancel or remove that " brake pull/press " option , i need just open red button+triger start button and run.
New command panel mounted (original is damaged) , cables+connectors changed/replacement all news water ress. bonus ( lancet drill my hand deeper, don play or dont try at home :P )
Old 11-22-2015, 02:00 PM   #2
Jay In Milpitas's Avatar
Ummmm,,,,,,,,,, okay.
I have to think a while and then get back to you. I promise.
Old 11-22-2015, 02:04 PM   #3
Co2   Co2 is offline
Thank you
Old 11-22-2015, 02:04 PM   #4
I forgot to ask, electric start or only foot?
Old 11-22-2015, 02:11 PM   #5
CO2,
If I understand correctly, you want to eliminate the clutch safety. In other words, you want to be able to start the engine without pulling the clutch lever. Is that correct?
Old 11-22-2015, 02:21 PM   #6
Co2   Co2 is offline
Yep electric start procedure request brake pull/press ( brake lights on, brake switch on )+start triger or button.
İ want open contact key offcourse, + trigger start.
Old 11-22-2015, 02:22 PM   #7
Co2   Co2 is offline
CO2,
My model is brake's contact to start way. not clutch. if i cant pull brakes / not actived brake light, ignition not start, march motor worked but coil not i want solved that problem., this is a little secrty option, i cant need that my moto im only used.
Rx3 how start first? clutch (clutch switch?) + start button?
Old 11-22-2015, 02:30 PM   #8
Adjuster's Avatar
I believe he wants to eliminate the brake/safety start switch.
If you unplug the brake/safety switch and jumper the two wires will that do it?
Or does that make the brake light constant on?
Old 11-22-2015, 02:34 PM   #9
Co2   Co2 is offline
Old 11-22-2015, 02:53 PM   #10
Lee R   Lee R is offline
Lee R's Avatar
WTF
I must admit to doing one of these 0_o at those wiring pictures!
Old 11-23-2015, 06:56 PM   #11
Co2, if Adjuster has answered your problem, then very good. That is a simple fix.
Am I the only one here that remembers when the only electrical safety devices motorcycles had were a charging light and a high beam indicator? Some of my bikes didn't even come with a neutral light. Sissy riders these days.
Old 11-24-2015, 05:50 AM   #12
Co2   Co2 is offline
Accurate diagnosis, and right terminology by Adjuster (lang.) ( i cant make, i will waiting spare parts, but before i need tip)
This is a not a problem for electrcl system, this general modern motocycle's start procedure (childs, noobs safety or idk.)
İm be disturbed that brake+start button motor start.
Yep bike have all indicators, süpermoto version is legal traffic road on traffic id plate , dijital panel , (highbeam/low/turn signals/gear1-5/speed km-mile/tripmeter/ neutral /heat warn-but not sensor of heat^^)
İm to bit a old thinks and classic , every time pull brake+start buton wrong for me my problem this.
İ think this is a not simple theme, probably dijital panel , or CDİ sett that idk, maybe cant touch best methode.
my sett new eletri circuit is work not any problem(not now/not yet^^ )
