11-17-2015, 07:16 PM | #1 |
Checking Bearings???
I have my rear wheel off messing around with it. It has 3 bearings in it. 2 in the wheel hub and 1 in the sprocket carrier. I stick my finger in the bearings to spin them around and feel them. 1 bearing spins smooth and feels what I think to be good. 2 of the bearings spin but with a noticeable 'notchy' feeling. Are the 2 'notchy' bearings shot and need replaced?
11-17-2015, 07:39 PM | #2 |
Probably could just get all 3 Yes. Bad
11-17-2015, 07:44 PM | #3 |
How do I knock the bearing out of the wheel hub? I watched a YouTube video that showed sticking a screwdriver into the hub from the opposite side and punching out the bearing. But that guy had a space inside the hub to get behind the bearing. My wheel hub does not have that space. Inside my hub is a bearing, then a metal sleeve, then a bearing. The metal sleeve makes my wheel hub completely smooth inside with no lip/space to get behind the bearing I want to knock out.
11-17-2015, 10:53 PM | #4 |
If it's like China hubs I've had, the tube spacer can be knocked a little out of position. After that, I've decimated bearings in the removal process. No matter, since Japanese sealed bearings are cheap.
11-17-2015, 10:57 PM | #5 |
Yeh I purchased 6 brand new bearings several weeks ago for $5.00. Looks like all the bearings in the front wheel and rear wheel are the same size.
11-18-2015, 12:06 AM | #6 |
Get a bearing removal kit, or the individual pieces which fit your bearings. I have used this tools for years, and I love it. It makes bearing removal an easy process.
http://www.ebay.com/itm/MOTORCYCLE-A...442111&vxp=mtr Here is how you use the tools to remove bearings. Check out Brother Dan's Motorcycle Repair Course on this subject. http://www.dansmc.com/wheelbearing.htm
11-18-2015, 01:40 AM | #7 |
Clever. I might include that in my next TB order, if I can find one. I've purchased other tools that way.
11-18-2015, 06:52 AM | #8 |
Dam something else I need to buy now
and you say Weld is an instagator
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp, |
11-18-2015, 08:26 AM | #9 |
Narrated mainly in Taiwanese Hokkien
11-18-2015, 09:33 AM | #10 |
I like this style puller as well
11-18-2015, 11:05 AM | #11 |
I like that style as well, although the puller bears on the hub, which would matter if any of my bikes had shiny paint.
11-18-2015, 12:22 PM | #12 |
You can buy a blind bearing puller at Harbor Freight, or Rocky Mountain ATV/MC.
http://www.harborfreight.com/3-jaw-p...ller-4876.html http://www.harborfreight.com/blind-h...ler-95987.html However, the tool I recommended works much faster, as well as preserving shiny paint, et cetera.
11-18-2015, 12:23 PM | #13 | |
