Old 10-16-2015, 02:45 PM   #1
Danimal   Danimal is offline
Banned
Valve clearances
Is everyone seeing the same thing upon their first valve inspection, that the gaps are too wide?
I haven't done mine yet, but have seen multiple reports that the gaps are too wide, even after 1000 miles. (supposed to be .06, measured at .1 or something to that effect)
Too wide is better than too tight.
Do we think Zongshen is trying to compromise, assuming that many owners won't check or adjust their valves often enough?...and maybe leaving them wide in order to allow more leeway?
Lee's recent post about poor mpg started me thinking. I'm just through my first tank of gas, and after this coming weekend will no doubt be around 500 miles or so.
Lee did also post about top speed, and his was right in line with others, indicating the motor is running well?
Just trying to understand.
Old 10-16-2015, 03:10 PM   #2
Adjuster's Avatar
I am guessing its simply because of a new engine that needs to be broken in. Get some miles on the engine and then the valve gap will settle down. Right now you set the proper gap but the engine has a lot of 'give' per say making the gap quickly and dramatically change. After the engine is broken in the proper gap will hold.
Old 10-16-2015, 03:30 PM   #3
Banned
If that is the case, then WHY adjust to "correct" clearances as early as 500 miles if the motor is not fully broken in yet?
Who here has checked their valves at 1000 miles and still found them loose?
Old 10-16-2015, 03:35 PM   #4
Adjuster's Avatar
You should always check and adjust your valves to proper setting. Just expect the first few times to have some wiggle room.
Old 10-16-2015, 03:52 PM   #5
Originally Posted by Danimal View Post
Is everyone seeing the same thing upon their first valve inspection, that the gaps are too wide?...
No, my valves were tight. Several others also reported tight valves.
The only way to know is to check the valve lash yourself. I do suggest you follow CSC recommendations, and check the valve lash at 500 miles.
Old 10-16-2015, 04:45 PM   #6
Lee R   Lee R is offline
Lee R's Avatar
Danimal,
I'll know this weekend as I just hit 500 miles and am doing the first round of maintenance. I don't think anything is wrong with my bike, it's more a Yeti with a heavy right hand that's causing the MPG issues. I'll be adjusting a friends who bought at the same time as well. I rode his bike and it's no different than mine.
My Guzzi also uses screw adjusters and they were tight the first couple of checks even with me setting them to the loose end of the spec. I'm expecting the RX3 to be as well.
I'm also purposely going slower to see if I hit 65-70mpg. If that's the case then I know it's me and won't worry about it after that. I've been riding a lot of trails also which is probably part of it. Loose sand hill climbs probably aren't good for mpg I've got to say this RX3 is the best dirt bike of the adventure bikes!
Old 10-16-2015, 06:35 PM   #7
Riceburner   Riceburner is offline
Riceburner's Avatar
Location: Tigbauan, Iloilo City, Panay Island, Philippines
My valves were "tight"...
Riceburner
Robin / Face Hunter I
Medical Mission Matters
www.medicalmissionmatters.org
Old 10-16-2015, 06:48 PM   #8
pete   pete is offline
pete's Avatar
In the first few thousand km is when the motor dose the most
settling in...
I would rarther see lose vavles over tight dueing that time...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 10-16-2015, 10:29 PM   #9
Originally Posted by Lee R View Post
Danimal,
I'll know this weekend as I just hit 500 miles and am doing the first round of maintenance. I don't think anything is wrong with my bike, it's more a Yeti with a heavy right hand that's causing the MPG issues...
Now you did it; you made me homesick. I was raised in Pennsylvania, and I miss the wonderful fall foliage. Thanks for posting the beautiful photograph from upstate New York.
P.S. I think you are correct. If you are easier on the throttle, I think you will see a big boost in gas mileage.
Old 10-16-2015, 10:32 PM   #10
Translation:
My valve clearances were less than the specified minimum of 0.04 mm. Therefore, the space between the valve tappet and valve stem was too narrow for the feeler gauge, or 'tight.'
Old 10-16-2015, 10:33 PM   #11
settling in...
Amen. Slappy valves are happy valves. Loose valves are better than tight valves.
Old 10-17-2015, 06:30 AM   #12
Riceburner's Avatar
Translation:
Yeah SudRider, that's what I said... , ,
I could not get a 0.04 to fit; I wrote down the gap but don't have it here with me now but baby, it was tight...
Riceburner
Old 10-24-2015, 02:37 PM   #13
Lee R's Avatar
I'm checking mine right now, intake valves were both below .038 which is the smallest feeler I have. I set them to .06mm.
Spark plug was in good shape so that's a good sign.
Now I'm staring at the front trying to figure out how to get to them. My hands are huge and it may require removing the radiators.
Old 10-24-2015, 05:03 PM   #14
Lee R's Avatar
Well thankfully the exhaust valves were about .065 so a little loose and I left them that way. That is one hell of a pain if you have large hands to get too. I'm just pulling the radiators off and changing coolant next check.
My Guzzi takes an hour to do both cylinders as they are both fully exposed and 4 bolts to open. This one took me about 4-5 hours with a good 3 hours messing with the front.
Pulling the regulator/rectifier off lets you move the left radiator a bit further back but not enough for me.
Get a t-handle or 8 inch socket extension as a wrench will be very difficult on the left radiator top bolt.
Intakes were less than .038 and adjusted to .06mm
Exhaust were .065mm in the first 500 miles.
Lee
Old 10-24-2015, 06:29 PM   #15
rtking   rtking is offline
Tight valves on mine at 200 miles. Exhaust was tough, but having to do the job a couple of times (don't ask), I've got the process down and only loosen the left side radiator to do this job.
