Old 10-04-2015, 01:19 AM   #1
toadstepper   toadstepper is offline
Head Scratching If you could go back in time...
So I pulled the trigger and ordered a Bashan 250 this past week!
I'm as excited to learn about the machine as I am to ride it! And I'm so glad I found this great resource for information! I have been digging into countless posts and trying to learn as much as I can. I'd like to tap once more into this group's collective experience and ask the following....
Looking back on the first days and weeks you had your bike, what do you wish you were more prepared for? Is there something you found you needed that, had you had it prior to getting your bike, you would have been better off - be it mechanically or comfort-wise? You see where I'm going here...
I've already got the safety course down along with safety equipment (helmet, gloves, jacket, etc.) and some basic tools, some chain lube, and axel grease. What else should I look be thinking about?
Thanks!!!
Old 10-04-2015, 04:31 AM   #2
jjn   jjn is offline
Bashan makes two 250 dual sports. The Storm, and the Will. Which one did you order? The Storm is more common it seems. Oh, and where did you order it from?
Jon, in Keaau, Hawaii
Old 10-04-2015, 09:48 AM   #3
It is the Storm. Sold under the name Roketa which from what I'm reading is really more commonly known as the Bashar. I got it from SuperiorPowerSports.com. So far they have been very responsive to questions. I'm just in waiting mode now...
Old 10-04-2015, 12:05 PM   #4
mjstef   mjstef is offline
Has the gas cap leak been addressed yet? Other than that an a few issues with the UDF leaking they seem to be pretty solid. I almost went that route as i REALLY wanted a counter balanced engine but got a hell of a deal on 2 Hawks.....
Old 10-04-2015, 04:04 PM   #5
tmec808   tmec808 is offline
bump
Old 10-04-2015, 06:26 PM   #6
Man, sorry to hear about your troubles. I don't know anything about these bikes (yet) but after reading through your post it stood out to me how the rear shock didn't seem to fit without the extra washers. Is it possible they included the wrong rear shock? Maybe a shorter one would give more clearance over the frame.
Also, I don't know about the gas leak issue on the latest being shipped but will deal with it if I have to. I picked this bike in part because of the overall good reviews and also because I'll be able to touch my toes to the street at a red light.
Old 10-04-2015, 07:02 PM   #7
jjn   jjn is offline
The TMEC's that I have read about by owners, had been pretty much all good, til this one. culcune liked his first one (that he bought used) so much, that he bought another. I Hope that this latest one gets worked out somehow.
The gas leaks on the 250 Storm's has been from the gas caps. Don't fill your tank to the brim. I would run my first tank maybe just over half full. Then, fill it a bit more each time. Maybe try leaving it at a couple of inches down. In one case, the gas came out of the cap, and got onto the tank plastics and ate the paint off quickly. There is at least two owners that complained of this fuel leak from the cap. Just be aware, and, if yours leaks, try having the seller get you another one.
Looking forward to hearing about your new Storm!!
Old 10-05-2015, 02:16 AM   #8
Thanks!!!
Congratulations.
I suggest you get a spoke wrench. It's important to keep the spokes tight if you want the wheels to remain true.
https://www.rockymountainatvmc.com/p...y-Spoke-Wrench
https://www.rockymountainatvmc.com/p...oke-Wrench-Set
Old 10-05-2015, 08:13 AM   #9
Congratulations.
Good advice! I've got one on order!
Old 10-05-2015, 12:30 PM   #10
Louis Angel   Louis Angel is offline
Louis Angel's Avatar
Not sure where you are at, but if you plan on riding in the cold,
this little guy is worth it's weight in platnum!!!!
clicky----> http://www.amazon.com/Under-Armour-C...mour+face+mask
" If it ain't broke, I can probably still fix it!" ---- Tim Allen
newbie bashan 250
