Old 10-02-2015, 12:54 PM   #1
Danimal   Danimal is offline
Banned
Front and rear axle nuts. What size?
Title says it all. Anyone?
Old 10-02-2015, 02:03 PM   #2
Banned
not looking at thread size or pitch...just the outer nut size
Old 10-02-2015, 04:25 PM   #3
I believe the front axle nut fits a 19 mm socket. I always use a pair of crescent wrenches to remove the rear axle.
Old 10-02-2015, 04:39 PM   #4
rtking   rtking is offline
On the rear, it is 17mm (nut) and 18mm (bolt head) per the CSC tutorial:
http://www.cscmotorcycles.com/Articles.asp?ID=257
Old 10-02-2015, 06:21 PM   #5
Jay In Milpitas's Avatar
Just went out & measured.
Both front & rear axle nuts are 19mm, 3/4" will also fit (I tested).
Rear axle head is 18mm. 11/16" may or may not fit, depends on tolerance of the wrench/socket.
Hope this helped.
________________________
If it doesn't say "Made in China" it's probably counterfeit.
Old 10-02-2015, 10:52 PM   #6
Thank you, Jay! You are correct 19mm nuts, 18mm bolt head (rear only).
