Old 08-16-2007, 02:32 PM   #1
fishman   fishman is offline
to unhook or not ???
I unhooked the smog stuff and blocked it of, cause i had heard hear that i could gain a little power ,now it runs worse,plugs shows a rich condition, where with smog stuff hooked up it was perfect.Now it won't idle,so i adjusted the idle,and ran the air screw in a turn and this has helped alittle ,but if you snap the throttle fast it the engine just dies.Is it worth it to screw around adjusting ,or just hook the smog stuff back up..
orion/viva 250 dirtbike,,,,Can-am 800outlander max-xt
Old 08-16-2007, 02:43 PM   #2
liverchip   liverchip is offline
Send a message via MSN to liverchip
What smog crud did you remove? Mine had an EGR appearing contraption that I removed. It made no real difference in the way the motor ran.I plugged the exhaust outlet and air box intake for it as well as the vacuum like. If the vacuum line is left hanging or is leaking the motor will suffer. Have you performed the c-clip carb. mod covered in the DS prep thread? If all else fails, put the crap back on and start from there.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 08-16-2007, 03:29 PM   #3
smog unhook
blocked everything you mentioned ,stuck bolts in the vacuum lines and zip tied them,did not do clip mod,cause with the smog stuff on it was running pretty good ,just not much power ,if unhooking this stuff does'nt do much ,i'll hook it back up.But what would help the throttle response?? ,If the throttle is snapped quickly it stalls.
Old 08-16-2007, 03:36 PM   #4
John22j   John22j is offline
sounds like not enough air -- is your filter clean and free flowing? You said it shows rich with also leans to not enough air (or too much fuel) -- lean it out or let 'er breath.... or put it all back together and see if you can get it to run as it did. :wink:
'20 RPS Magician 250
'06 Hensim (Tierra) DB150-2
'06 X-Treme 70cc pitbike
'02 Kawasaki KX125
Old 08-16-2007, 04:04 PM   #5
smog stuff
yeah, filter and bike are brand new ,think i'll just put it back the way it was ,unless some one can tell that unhooking it makes a noticable difference.
Old 08-16-2007, 05:24 PM   #6
If it continues to run really rich, I would move the needle clip up a notch and see if that takes care of it. What elevation are you running at?
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 08-16-2007, 08:32 PM   #7
smog stuff
inPA here I'm probably only 900' ,the plug burn was perfect ,before i unhooked ,will the needle -clip move help with the terrible throttle response?
Old 08-17-2007, 01:15 AM   #8
I believe the needle is active from idle to mid-throttle, so it should help. It's a painless adjustment that can always be reversed.
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
