09-12-2015, 07:07 PM | #1 |
Reviving a craigslist Taotao 50cc
PIcked up a 2014 ATM50-A1 off Craigslist for $100. It was in really rough shape but I wanted something cheap and easy to learn repair on. Seller described it as "will start, won't idle".
I don't know anyone could beat a scooter this badly in so short a time. I have only found one body panel so far that isn't damaged. Fasteners rounded off, stuff just hacked together. After reading on this forum here's the stuff I did before attempting to start. [Added: which it did. Starts fine now]
Other stuff I can't remember at the moment. Going to take it out on the patio for subsequent starts. I have a monster attic fan running which kept me alive during this short first run. :-) More news as I figure stuff out.
Current: bikeless for now, moved into a campervan. Past: Honda NC700x, Suzuki DR650, Taotao ATM-50-A1, Taotao Evo 150cc, Honda Spree 50 2str, 1982 Katana 550 Last edited by fratermus; 09-12-2015 at 08:17 PM. Reason: added valve clearance |
09-12-2015, 07:18 PM | #2 |
Ughhh, can't edit the first post to add a very short startup video link:
[Added: hmmm, can edit in firefox but not in Chromium]
Current: bikeless for now, moved into a campervan. Past: Honda NC700x, Suzuki DR650, Taotao ATM-50-A1, Taotao Evo 150cc, Honda Spree 50 2str, 1982 Katana 550 Last edited by fratermus; 09-12-2015 at 08:16 PM. |
09-12-2015, 08:14 PM | #4 |
Forgot to add that I did check/set the valve clearance. Intake was fine [at .04mm]; exhaust was tight [so I set it to .05mm].
Just got back from a test run. Pulled fine up to an indicated top speed of around 42mph. I guessing that's about 35mph actual. Regardless, it was fast enough for me on that wheelbase and with that tire size. CVT acted fine, keeping the rpm steady as speed climbed. No weird behavior. This is my first CVT so it will require some brain remapping until this "same rpm" thing sinks in. I had a 50cc Honda Spree before. It was a 2t and lighter so I would have expected it to be quicker, but the Spree had just the fixed speed. I was a little surprised how well the Taotao pulled around my 190#.
Current: bikeless for now, moved into a campervan. Past: Honda NC700x, Suzuki DR650, Taotao ATM-50-A1, Taotao Evo 150cc, Honda Spree 50 2str, 1982 Katana 550 Last edited by fratermus; 09-12-2015 at 08:19 PM. Reason: added clearance |
09-13-2015, 04:20 PM | #5 |
You've done all the right things; excellent job.
The idle in the video sounds a little high to me. Have you tried turning the idle speed down? If you do, does it stall?
09-13-2015, 11:33 PM | #6 |
Yes, I turned the idle speed down further than in the video. It hasn't stalled yet. I'll post another video of it running outdoors where the sound is more normal. Yes, I'm a bachelor and was doing the work in my living room. :-)
I just did 2 turns out on the idle mixture screw to get it in the ballpark. I need to watch another vid on tuning so I can set the mix better and set a correct idle. Thanks for the encouragement. I have found a lot of good advice in your posts specifically.
Current: bikeless for now, moved into a campervan. Past: Honda NC700x, Suzuki DR650, Taotao ATM-50-A1, Taotao Evo 150cc, Honda Spree 50 2str, 1982 Katana 550 Last edited by fratermus; 09-14-2015 at 05:41 PM. Reason: s/low/idle/g |
09-14-2015, 12:08 AM | #7 |
When you have some miles on your new scoot, perhaps you'd consider a free-flowing muffler, a pod filter and some fatter jets. That'll be a worth a few mph.
03-26-2016, 06:36 PM | #8 |
Update: the little 50cc is running fine. There are still some issues but I've largely stopped active work on it since I'm having $&^@ trying to get the title sorted. I am in communication with the original (actual) owner; he seems willing to help but keeps losing the paperwork I send him. :-(
I'll use this one for bashing around the microRanch and letting people learn on. I've picked up another cheap CL scoot (better title sitaution, everything signed by the single owner who also signed my TX title app, bill of sale, etc). I'll put that scoot in its own thread.
Current: bikeless for now, moved into a campervan. Past: Honda NC700x, Suzuki DR650, Taotao ATM-50-A1, Taotao Evo 150cc, Honda Spree 50 2str, 1982 Katana 550 |
