Old 09-07-2015, 12:02 AM   #1
rtking   rtking is offline
Steering head lock?
Sorry if already covered, but has anyone tried to lock the steering head by using the ignition key? It appears on the ignition tumbler that you can press down to lock the steering head, but mine does not turn to lock the steering head in either direction. Just wondering if this works for anyone/everyone else?
Old 09-07-2015, 12:16 AM   #2
detours   detours is offline
detours's Avatar
Try pushing the key down and releasing first, then turning to the lock position. I expected it to turn while pushed down, but it doesn't work that way.
Red 5 standing by!
2014 Ural Patrol
Old 09-07-2015, 12:46 AM   #3
Thanks Detours! That was exactly it!
Old 09-07-2015, 01:04 AM   #4
The RX3 ignition lock works the same as many, if not all, Yamaha ignition locks.
Turn the handlebars to full lock at the left.
Push down on the ignition key, and release the key.
Turn the ignition key left (counter clockwise) to the 'lock' position.
Remove the ignition key.
Old 09-07-2015, 01:06 AM   #5
I might be wrong, but I seem to remember the ignition lock will not work if the handlebars are turned to full lock at the right. I believe you can only lock the handlebars at the full left position.
Old 09-07-2015, 09:29 AM   #6
pepelepua   pepelepua is offline
pepelepua's Avatar
Hi,
It only loks to the left.
In my bike I donĀ“t need to push down the key and release before turning it left, if I turn it directly left with the handle turned fully left, it locks.
The ignition key and lock is the first contact you have with the bike and at the begining it was rough, after a few days it seems to became easier
Pablo.
Today Riding a Corven Triax 250 Touring (Zongshen RX3)
Old 09-07-2015, 09:59 PM   #7
AZRider   AZRider is offline
On my bike, I can lock the steering in the straight ahead position and it will only turn partially.
George
2016 CanAm Spyder F3-L
Old 09-07-2015, 10:41 PM   #8
Yes, that is the same result obtained if you turn the handlebars fully to the right, and lock the ignition. The handlebars will only fully lock, without any movement, if you turn them fully to the left, before you lock the ignition.
