Old 08-13-2015, 04:01 PM   #1
AZRider   AZRider is offline
If you don't have a JIS Phillips screwdriver......
I adjusted my valves today and decided that either I buy a JIS Phillips type screwdriver or replace the screws for the body panels. Since I have a full set of good quality screwdrivers, but no JIS, I decided to head down to Home Depot and see what they had. What I found were #8x1/2 inch gutter screws in a box of 25 for about $4.50. These particular ones were brown, but the color blends in very well with the body panels and most of the screw heads are hidden anyway. I'll replace the rest as I remove other panels in the future.
George
2016 CanAm Spyder F3-L
Old 08-14-2015, 12:13 PM   #2
Thanks for sharing the great tip, George.
Old 08-14-2015, 03:00 PM   #3
Good idea. JIS is a pain without the correct tool.
Old 08-15-2015, 12:03 AM   #4
jct842   jct842 is offline
I have gotten by so far by grinding off the point on the screw driver just a little at a time till it fits the jap screws. Got one philips that I went too far with that still works great but impossible to get started in the screw when you go in blind. When you go a little at a time you can actually see the driver seat deeper and deeper, just don't go too far.
