Zongshen Sierra Progress
So the day has finally come where my bike is FINALLY working again after 2+ years. The most recent modifications were a new stator, CDI, & gaskets. I did about 50mi on it today and it works like a champ! No more stalling at red lights and stop signs, random dying, etc. The only things I need for it are the following:
- New battery - Shorter brake cable (I lowered it a bit so it needs to be 3in shorter) - Correct size rear sprocket (I ordered what Spud's link said but the mounting holes were slightly off?) - Something that I'm calling a control arm bushing? Mine is nearly disintegrated. Its located below the swingarm, very difficult to get a good picture of. If it helps, I have the updated XT225 swingarm. Any suggestions as to where to purchase? - Ordered the large JC Whitney trunk, it should be here Tuesday! - Turn signals randomly stopped working. I looked over wiring and everything looked fine except a black cable from the turn signal was unplugged. When I plugged it back in, nothing changed so I left it unplugged for now. All other lights are working fine. See pictures below, and enjoy the ones from today's ride as well! |
#2 | ||||||
![]() Quote:
![]() http://www.batterystuff.com/powerspo...ies/YTZ7S.html Quote:
![]() Quote:
![]() Quote:
![]() Quote:
#3 | |||
I will take a picture and upload as soon as possible. All turn signals are currently not working, but rear brake, high & low beams work fine. I'm thinking the black wire is the ground, but I'm not 100%. Going down to take some pictures now. |
#4 | ||||
![]() ![]() Quote:
![]() Quote:
![]() Quote:
Here is an album of pictures I took so far. I am going down right now to take some more.
http://imgur.com/a/jmAPm |
Thank you.
I am awaiting your additional photographs for verification, but based upon the photos you provided, I have reached the following conclusions.
![]() You bike does have an XT225 rear wheel. Therefore, the JTR468 sprocket will not fit. You need to get a rear sprocket for the Yamaha XT225. ![]() It seems the previous owner modified the stock (original), Zongshen shock absorber to fit the XT225 swingarm. Your XT225 swingarm does employ the Yamaha, progressive, lower shock linkage. I believe you are trying to replace that lower shock linkage. If so, you can find that item for sale in used condition at eBay. ![]() http://www.ebay.com/sch/i.html?_odkw...nkage&_sacat=0 The previous owner of your bike installed LED turn signals. If your turn signals suddenly stopped working, I suggest you check all the connections to the turn signals. That black wire probably is a ground wire, and it does need to be connected. You should also check the turn signal flasher and the main fuse. ![]()
Ok that link is officially ready to go. If there are any other images you need, I am outside now so I can upload them quickly. I have also posted a picture of my "solution" for the brake cable for now (it was starting to get singed from the exhaust) and my horn. I'm looking for suggestions as to where to locate the horn or where its worked for people in the past. Mine currently doesn't work, but I'm going to get a new one soon and see if that solves the issue.
#10 |
Thanks for posting the additional photos. I stand by my conclusions in post #7 of this thread.
![]() I suggest you measure the length of the current brake hose, and then order a custom brake hose of the desired length. Galfer, and some other companies will sell you a custom brake hose of any length you desire. ![]() I relocated my horn behind the headlight. ![]()
#11 |
Thank you SO much for all your help. I'll have to start ordering!
#12 | |
#13 |
It certainly looks like that Sierra has been Spud-ified. I wonder if a former member owned that bike.
#14 |
I also recommend you consider purchasing a used, XT225 shock absorber from eBay. The XT225 shock is far superior to the modified, Zongshen shock absorber which is currently installed on your bike.
#15 | |
