Old 06-13-2015, 12:56 AM   #1
woodlandsprite's Avatar
Center Stand Install
So, I know to squeeze coins into the spring to expand it to install....
Is it as simple as position the stand, send the pin through, secure the ends of the pin using the little C rings (upper left - speaking of which, is there a trick to getting these on?) then bolt on the tab (look under the bike for the corresponding hole in the frame), then mount the spring?
Old 06-13-2015, 03:40 AM   #2
Yes, I would install the center stand exactly as you describe.
I would use a pair of pliers to coax the circlip onto the end of the mounting pin. If necessary, you can use two pairs of pliers to grip, and spread the wings of the circlip. Widening the wings of the circlip might ease the installation.
Old 06-13-2015, 07:53 AM   #3
JTHSPACE   JTHSPACE is offline
JTHSPACE's Avatar
Where possible (spring fitting), wear a pair of gardening gloves or similar, I have had these things try and bite me more than once
Riding bikes for over 40 years
Honda C50 / SS50 / CB125 / CB250
Velocettes (various)
Piaggio's / Honda's / Yamaha's
Raptor . . . . the List Goes On . . . .
Old 06-13-2015, 11:02 AM   #4
I recommend Loctite 242 when bolting the tab on.
Please show us pics of the completed installation.
Old 06-13-2015, 01:20 PM   #5
X2 on the gloves, loctite, and request for photos.
Old 06-13-2015, 06:27 PM   #6
fishman10's Avatar
centerstand
heres mine,,,,,,,
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 06-13-2015, 06:34 PM   #7
humanbeing's Avatar
the Tool ? http://www.motorfans.com.cn/bbs/view...authorid=75082
Old 06-13-2015, 06:46 PM   #8
I wish I could show you all a photo of the installed stand....
I ran into a small problem:
After trying to get it positioned and much cussing, I gave up and got my micrometer...
uh...anyone have a grinder I can borrow? I do have a flat file, I could probably take a hair off either side of the center bit of the center stand to make it fit...but there is no way it's going in there the way it is now.
Old 06-14-2015, 12:24 AM   #9
I fear you will be filing a long time. I would either trim the center stand with an angle grinder, or have CSC send me a center stand which fits.
Old 06-14-2015, 12:26 AM   #10
Originally Posted by fishman10 View Post
heres mine...
It looks good, Fish. How do you like the center stand?
Old 06-14-2015, 12:34 AM   #11
That photo was dispatched to CSC before I posted it here I called and left them a voicemail before I was clever enough to get the calipers.
Old 06-14-2015, 08:39 AM   #12
fishman10's Avatar
Centerstand
spud,, while it does make lub ing the chain an adjusting the rear shock easier (btw the rear shock is abysmal ). It's only good for street use, as you can see it hangs down very low
Old 06-14-2015, 11:22 AM   #13
JTHSPACE's Avatar
Originally Posted by humanbeing View Post
That looks a useful homemade tool, one of those that someone makes and it is used one or twice in a lifetime, but is worth its weight in gold.
Old 06-14-2015, 11:43 AM   #14
AZRider   AZRider is offline
I have a grinder and if you're within a reasonable distance of Phoenix, I've been known to travel for a good cup of tea. Must be the Brit in me.
George
2016 CanAm Spyder F3-L
Old 06-14-2015, 12:08 PM   #15
That's less than 0.5mm difference. I bet a few love taps with a hammer would widen the mount enough so that the stand slips right in.
