Old 05-16-2015, 11:54 PM   #1
woodlandsprite's Avatar
Breather tube length
So... Just how long is the breather tube supposed to be? Because mine seems to dangle a good 3 inches or more out the bottom of the bike. It just looks kind of odd dangling there.
Old 05-17-2015, 12:08 AM   #2
Actually, longer is better than shorter, since it is more likely to vent to the ground, rather than the motorcycle. However, if you wish, you can safely trim several inches from the tube.
Old 05-17-2015, 01:21 PM   #3
Agreed. I'd leave it alone.
Old 05-17-2015, 04:44 PM   #4
Inroads   Inroads is offline
I've had an inch or two of fuel/oil that I've dumped in my break-in.
Old 05-17-2015, 05:06 PM   #5
I think we might be talking about two different vent hoses. The crankcase breather tube is located at the front left side of the engine. It collects excess oil which is vented from the engine. I definitely wouldn't tamper with any of the hoses in that assembly.
However, there is another vent hose which descends behind the swingarm bolt, near the lower shock linkage. I haven't traced it back to its origin, but I think this hose vents the evaporative canister. I believe this is the hose Sprite was inquiring about, and it is the hose I have been discussing.
Old 05-17-2015, 05:57 PM   #6
oldqwerty   oldqwerty is offline
Obviously, Sprite, your Cyclone is a male, which would make it a himicane.
"Thou shall not Zong" is not a commandment.
Old 05-17-2015, 06:16 PM   #7
Well if it is a he, his bits are at risk for getting abraided if he insists on dangling them so far below the rest of the bike! It's positively indecent, I tell you!
Old 05-17-2015, 07:46 PM   #8
TMI!
Old 05-17-2015, 07:58 PM   #9
TMI!
I'll spare you a photo then
Old 05-21-2015, 02:41 PM   #10
rjmorel   rjmorel is offline
rjmorel's Avatar
Nothing wrong if you own a zong with a ding don....... Oh never mind. rj
Old 05-22-2015, 10:18 AM   #11
jimjr21   jimjr21 is offline
The center tube is the overflow from the fuel tank fill cap
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 07-01-2015, 12:46 AM   #12
Scrami71   Scrami71 is offline
Inroads,you said you had fuel/oil in your crankcase exhaust tube? Did you ask CSC about it. If so what did they tell you. Also has it happened again?
Scrami71
RX3
Triumph Speed Triple
http://tarmacstrails.net/
Old 07-01-2015, 02:25 AM   #13
rjmorel's Avatar
I also had 1-2" of oil in crank case vent tube when bike was first new. I called CSC and they said to just take the black plug in the end out and not worry about it and let it vent away. I took the plug out and drilled a 1/16" hole in it and reinstalled it back in the tube end. My reasoning is if I ever got into a water crossing that could reach the tube the plug could stop most of the water from filling the tube but it can still vent ,drain out all the time so I don't see the 1-2" of oil being built up any more. rj
Old 07-01-2015, 02:40 AM   #14
The plug is there so you can retain the oil for safe environmental disposal. You can remove the plug and add the oil from the tube to the dirty oil you collect every time you change the engine oil.
