Old 05-16-2015, 11:10 PM   #1
AZRider   AZRider is offline
Making it mine
I thought that I'd start a thread about the little changes that personalize a bike to it's owner. I'll get this off to a colorful start with a color change to my panniers. The color match isn't perfect, but at 60mph who's going to notice?
George
2016 CanAm Spyder F3-L
Old 05-16-2015, 11:27 PM   #2
Nice job! The color match might not be 'perfect,' but it looks pretty good to me. What paint did you use?
Old 05-16-2015, 11:30 PM   #3
Adjuster's Avatar
Looks great!
Old 05-16-2015, 11:40 PM   #4
jct842   jct842 is offline
A bit late now but these places that have computer paint mixing are supposed to be able to match paint perfectly. I was going to try it right before my chinese scooter got tangled up with a dog under the front wheel. John
Old 05-16-2015, 11:42 PM   #5
I was walking through my local Walmart and saw that they had some spray paint odds and ends on clearance for $5. The paint is Rust-Oleum Caliper paint and in the store the color looked like a good match, and after application was still pretty good. I had some clear coat and after 4 coats of paint, I applied 3 coats of clear.
George
Old 05-16-2015, 11:47 PM   #6
Other than free, 'clearance prices' are the best prices. I can't tell a difference from the photograph, which means most people will never notice a difference while viewing the bike in person.
Old 05-17-2015, 08:54 AM   #7
Huck369   Huck369 is offline
Huck369's Avatar
Looks good
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 05-17-2015, 01:38 PM   #8
That's a good look. It would be a nice detail to have a bit of the same red on the trunk as well, like a small pin stripe. Maybe there is pin stripe tape in a similar red also.
Old 05-17-2015, 05:12 PM   #9
oldqwerty   oldqwerty is offline
SUH-WHEET!!!! I'm so glad I sent my son to WyoTech to learn how to refinish motor vehicles.
"Thou shall not Zong" is not a commandment.
Old 05-17-2015, 07:33 PM   #10
woodlandsprite's Avatar
George, can you fit a full face helmet in that travel trunk? and did you have to change out the mounting plate on the bike to get it attached? I'm thinking I need a slightly larger top case than the stock CSC one...
Old 05-17-2015, 08:55 PM   #11
You're right, but I also use this case on my Valk and the reds don't match. If I decide to use it exclusively on the RX-3, then I'll stripe or paint an accent section. Thanks.
A full face helmet will fit and this Coocase was designed with that in mind. Unfortunately, this particular model, the V-28, is no longer available so you may have to do some research into finding an equivalent. It comes with a base plate that is held onto the rack with 2 nuts and bolts that line up with precut holes in both the rack and base plate. It's very sturdy, but if you were to take on a passenger and use the case as a backrest, I would add a third nut and bolt. For that you would probably have to drill the rack.
I did have another rear case for a while from JC Whitney that was much larger, 48 liters I believe, but it was old and didn't hold up to offroading.
George
Old 05-17-2015, 09:34 PM   #12
Huck369's Avatar
I've used the large travel Trunk from JC Whitney on several bikes for years...it is a know off of a GIVI, and will hold most full face helmets....for under $50.00 ...I used the CSC mounting plate and mounting points, bolted on the Trunks plate(Had to drill the Trunk's Mounting plate to match the 3 holes in the CSC plate) I've posted a couple pics...but don't have them here with me...
The trunks are a great value...this newest ones mounting plate is thinner metal than the earlier ones I've had, but does the job OK
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
Old 05-18-2015, 01:54 AM   #13
Yes, I love the J.C. Whitney/Garage Pro Travel Trunks.
http://www.chinariders.net/showthread.php?t=12271
http://www.chinariders.net/showthread.php?t=14279
Old 06-14-2015, 11:16 PM   #14
Added a Ram GPS mount between the windshield and instruments. Makes for a better sight line.
File Type: jpg tmp_16236-20150614_184340-1087353754.jpg (84.7 KB, 191 views)
File Type: jpg tmp_16236-20150614_185814-685457693.jpg (85.9 KB, 169 views)
File Type: jpg tmp_16236-20150614_191139-459652380.jpg (87.1 KB, 176 views)
George
Old 06-14-2015, 11:22 PM   #15
A few more pics.
File Type: jpg tmp_22424-20150614_1914452141301313.jpg (85.1 KB, 207 views)
File Type: jpg tmp_22424-20150614_191512-1087353754.jpg (95.5 KB, 178 views)
George
