05-04-2015, 04:57 PM | #1 |
rx3 battery trouble
if i let the bike set for more than a day ,,,the battery barely has enough juice to startit..I know its charging it cause after riding an then restarting it spins the engine over quickly an fires right up,Im thinking bad battery.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
05-04-2015, 09:33 PM | #2 |
Likely. That's one thing I expect will not last. An upgrade to an AGM is a good plan.
05-04-2015, 10:00 PM | #3 |
Be sure to check that there isn't a current draw when the key is off.
05-05-2015, 01:04 AM | #4 |
The Zongshen RX3 comes equipped with an AGM battery.
05-05-2015, 01:07 AM | #5 |
I believe the Siemens digital dashboard draws a very small parasitic drain on the battery. However, this is the only parasitic drain, and it has not caused any problems with my Zongshen RX3, which now has about 900 miles on the odometer. The stock AGM battery has a capacity of 11 amp-hours.
05-05-2015, 01:09 AM | #6 | |
05-05-2015, 01:20 AM | #7 |
That's one detail that I missed in all the excitement about the RX3.
05-05-2015, 01:23 AM | #8 | |
05-05-2015, 01:29 AM | #9 | |
I was surprised to see that model of Yuasa is made in the USA.
05-05-2015, 08:38 PM | #10 |
battery prep
Spud i prepared the battery just as shown ,,,,You'd have to let your bike sit more than a day ,,to see if you have this issue.....lol,,,,,,But that aint happening........!!!! Nor should it.
05-05-2015, 09:40 PM | #11 | |
I suggest you measure the resting voltage after the bike sits overnight. A new, healthy, AGM battery should have a resting voltage of 12.7-12.9 volts. If the resting voltage is lower, check the voltage at the battery terminals the next time the bike is running. If the voltage is around 13.7 volts, the regulator/rectifier is good, and it is charging the battery. If the resting voltage is low, and the voltage with the engine running is correct, then you must have a bad battery, and I would contact CSC for a replacement. My RX3 has sat for several days without running, and the small parasitic draw from the Siemens digital dashboard should not lower the resting voltage of your 11 Ah, AGM battery after a mere 24 hours.
05-06-2015, 06:21 PM | #12 |
bad battery
thx spud,, i will give that a try..
05-08-2015, 06:52 AM | #13 |
battery
CSC is great,,,,they are sending a new battery!!
05-08-2015, 07:02 AM | #14 |
That's great. CSC really does provide excellent customer service.
05-08-2015, 11:22 AM | #15 |
Excellent! They seem like a top-shelf bunch.
