Old 03-17-2015, 11:38 AM   #1
baerboy22   baerboy22 is offline
Question Star X/Gio 250cc Dirt Bike Clutch Issues.
Hi, I'm really new to this forum, and the reason I am on here is because I cannot figure out how the clutch works on my dirt bike. I was hoping you one of you guys might have a understanding on how the clutches work on these bikes, as I can not find any information at all on Google/Youtube.
My bike is a Star X 250, which appears identical to the Gio X31 (Picture in the link). The problem I am having is; When I start the bike it neutral, it starts fine, then when I depress the clutch and put it into gear, it starts driving right away, before I even let out the clutch.
I already did everything it says to do in the other forums, checked the clutch cable, cleaned the clutch plates, etc.
Old 03-17-2015, 03:48 PM   #2
Welcome!
Your clutch operates just like a Honda XR200, and there are plenty of vids of that on Youtube.
Your cable needs some adjustment. How much freeplay do you have now? Freeplay is measured between the lever and the perch.
Old 03-18-2015, 10:37 AM   #3
Hey thanks, that helped a lot. I got it fixed last night, even took it for a quick test drive. Can't wait to hit the trails come sunday
Old 03-18-2015, 10:49 AM   #4
Glad to hear it!
May we see pics of your bike?
Old 03-18-2015, 10:53 AM   #5
I tried uploading some with my first post, but the file size it much too large due too my phone camera being too high res.
Did the link to the photo work in my original post?
Old 03-18-2015, 10:55 AM   #6
Nope. Just a little X.
Can you upload your pic to a third party, like Photobucket? If so, you could link it back here.
Old 03-18-2015, 11:09 AM   #7
http://i.imgur.com/Ntf1rWa.jpg This should work..
Old 03-18-2015, 11:15 AM   #8
I don't actually have a clutch cable on, in that picture.
Old 03-19-2015, 12:46 AM   #9
Sweet bike!
I linked the pic here, but it's too large. I'll try to reduce it.
Old 03-19-2015, 01:00 AM   #10
Old 03-19-2015, 11:07 AM   #11
I took it out for my first ride yesterday, was great. Had no issues
But I have 2 more questions for you, how much slack should the chain have (how loose/tight)? Also how tight should the rear axle bolt be? I recently took off my rear tire to fix a flat, now I can't figure out how tight the I should make the bolt. Do you have a bike similar to this? Could you take a close-up picture of your rear tire?
Old 03-19-2015, 01:18 PM   #12
Mudflap   Mudflap is offline
On just about any bike you determine the chain adjustment by lining up the centers of the countershaft, swing arm pivot bolt, and rear axle bolt, then adjust the chain for 10mm to 20mm movement.
Old 03-23-2015, 11:05 AM   #13
Agreed. That may require you to remove the shock the first time, but after that, you'll have a feel for proper chain tension.
I've never used a torque wrench on the axle nut, but I make sure they're tight. A little Loctite 242 is always a good idea.
Old 04-14-2015, 11:42 AM   #14
I have another question for you, since you seem to know quite a bit about these bikes, what air filter can I use in my bike? Mine is really beat up, but I don't know which one I can buy that would fit in it.
Old 04-14-2015, 03:15 PM   #15
Try this one: http://www.ebay.com/itm/Red-42mm-Ang...e5ec4c&vxp=mtr
It'll fit the carb, but I'm not sure if it will clear the frame properly. The good news is that the foam will just conform, and the price is certainly right. I've installed several of these filters, and I use Maxima Fab 1 filter spray on them. Use a light coat.
