Lifan owners: Check your front brakes!
Just a heads up on the front brakes. I noticed than my front rotor is too small. I realize that sounds crazy, but I have pics to back it up!
![]() ![]() I marked a section of the rotor before riding. ![]() After the ride. You can see that the inner 10mm or so of the rotor hasn't been touched. ![]() Here are the pads. Towards the top you can see they are a lighter color where they do not contact the rotor. What will happen is that since the total thickness of the pad material is greater than the thickness of the rotor, eventually the pads will contact and squeeze against each other instead of the rotor.. no more front brakes! If the pads weren't hanging over the rotor, I wouldn't worry about this. The rotor needs to be about 20mm bigger. It might just be my bike, but I looked through the gallery and noticed that nearly every Lifan, Lifan clone and any bike with the same style rotor had the tell tale wear pattern on the front. A dull, unworn band on the inner section of the rotor. CHECK YOUR FRONT BRAKES! No joke, it could be bad. I've already contacted my dealer about my bike but I know many on here are on their own with something like this. With it being a safety issue I felt I really should get this out. |
I haven't checked my pads yet. Winters are long here and was hoping to look into brakes in Nov. How many Kilometers do you think you could have driven before the pads would have made contact? 8O
Quick fix could be to file down the non worn section, Should get You going for a few more miles.....Intersting find Knot head..I'll check mine.
#4 | |
Oh, the pads are keyed so they go back on with the same orientation they came off. |
Very cool knothead. 8) I've added it to my fix list. AZ200 thanks for the fix, at least you wouldn't have to walk to the bike store for brake pads. I hate walking to a cycle shop. :oops:
No prob N2R, What's interesting is that nobody has had a front brake problem..At least not that I can find. And some folks have a lot of miles on these bikes. But it makes sense that they could touch...... :?
#7 | |
Yours could have eventually that's for sure. Now I'm curious about mine. Mine seems to have a lot of the quirks from all the different bikes. The only exception is my speedo (knock on wood) it's still working fine. My bike is like a motorcycle repair course, all parts included, but no text. 8O I like learning. The only time I ride my bike is to test it lately. I've dropped and raised the needle in too many shopping malls and coffee shops to count now. I actually go home to switch jets.
Another angle...
When the pads are worn out, there will be no brakes, regardless of how they contact the rotor. That said, having the overhanging lip could save the rotor from damage by contacting the steel parts behind the brake pucks. I wouldnt necessarily call this quirk an emergency, since every rider should be religious about inspecting brakes regularly. |
#10 |
I think when they do start to touch you will not lose all braking all together. What will happen is the pads will be pinched at an angle and will start to wear unevenly from that point on. Either way I don’t like the looks of this because braking will still be degraded. I wonder why nobody else has noticed this. Could it only be on the 07's. They minght have a differnet setup. I’ll check mine tonight and see what they look like after a 1000mi.
When I was a kid I replaced the worn out front pads on my DR125 with leather. Just super glued on patchs of leather from a and old pair of boots. Oh the stupid things we would do to ride when we where kids. Worked great and lasted a long time if you can belive it. ![]()
Bone stock 2007 Lifan GY-5 |
#11 |
I can see the top of the disk and the pads without pulling my brakes. I have the same quirk, but as stated it would take a while before quirk becomes problem. I have about half the overhang that you do. Here is a new one, I don't think my disk is a perfect circle. I think the overhang rubs the top of the disk once everytime the wheel spins. I get weird noises, not just a squeel when backing up. I knew something wasn't 100%, thanks for the find bro.
#12 |
Yup, same thing on mine.
#13 | |
The leather brake pads don't surprize me. I used to have some leather that was used to line the brakes on a truck my grandad used to own... the super glue I'm surprized held up though! |
#14 |
knothead, I filed down the overhang on the pads, the spot that doesn't touch the disk. SWEET! SMOOTH. 8) braking. I think my disk is more of an oval than a circle, and that overhang was rubbing on the high spot on the disk once per revolution, even when not braking. I can now back my bike up without the brake squeeling like it did. 3200Km into my bike and the front wheel now feels correct.
#15 | |
