02-18-2015, 02:54 PM | #1 |
Koso clone installed
I picked up a Chinese clone of a Koso combo speedo/tach for $40 shipped to replace the units on my Panterra. The old speedo odometer had stopped working a couple of thousand miles ago and the speedo CAL was way off from when I changed from 21" to 18" wheels.
Anyway it came with no instructions and the wiring pin outs were wrong, but I eventually got it up and running. Supposedly you can switch from mph to KPH, but I couldn't make that work. So I fudged the CAL to get it to display correctly. Setting the clock was relatively easy and there should be a way to turn off the displays for fuel and water temp. ETA, here's the ebay listing http://www.ebay.com/itm/191395394751
02-18-2015, 03:59 PM | #2 |
I am interested, perhaps you could give a few more details about the following.
wiring - what was different from their displayed pinout buttons and menu selection - perhaps you could take a few pic of the screen as the buttons are pressed, held, etc. Also how you adjusted the sensor input. |
02-18-2015, 05:05 PM | #3 |
I notice it says universal on the listing, how does this mount up to the bike in a way that makes in universal? I am interested in picking one up as well.
02-18-2015, 05:48 PM | #4 |
it's universal in that you can use it on a 1 thru 4 cyl with wheels from 12" to 21". you have to make your own mounting brackets depending our your particular bike. I did a simple plate with a 15 degree bend in it and attached it to the previous clock mounts on the triple tree.
02-18-2015, 09:22 PM | #5 |
That is nice digital dashboard. Thanks for posting your review.
02-19-2015, 12:53 AM | #6 |
So, does it display in MPH or KM/H? How did you connect the tach?
Nice looking unit at a decent price.
02-19-2015, 03:39 AM | #7 |
Does the tacho read properly, because I tried one of these a few years back and the tacho would work only up to about 7000 rpm, and then it would drop to 0?
02-19-2015, 08:28 AM | #8 | ||
I was having a bunch of problems last night with it, the display would just go blank and the unit would re-boot itself. this may be caused by something else, because the starter relay died last night as well. I thought I might have damaged the unit at first but it seems OK. I have it rubber mounted due to the vibe issues on these bikes. Where's the best place to get a CG starter relay?
02-23-2015, 12:23 AM | #10 |
02-23-2015, 08:29 AM | #11 |
I used the existing wire from the old tach
02-23-2015, 01:26 PM | #12 |
Do you happen to know where that leads? is it inductive?
02-26-2015, 02:41 PM | #13 | |
I emailed the seller about km/mph display. Here is the response.
02-26-2015, 04:58 PM | #14 |
02-26-2015, 08:24 PM | #15 |
Did it work?
