Old 02-10-2015, 10:27 PM   #1
nathan93   nathan93 is offline
Mechanical question
I took off the silver cover in this pick with the three bolts and when i pulled it a gear two washers and a rod fell out. I put the rod in and then a washer then the gear around the rod then the other washer. Just wondering if it mattered how i put the gear in. As in if it affects timing or something idk thanks for any help.
http://www.todoautos.com.pe/attachme...-lf200gy-2.jpg
Old 02-11-2015, 06:32 AM   #2
Mudflap   Mudflap is offline
The part circled in the pic is the balance shaft. It cannot be removed without splitting the crankcase. Are you sure you didn't remove the electric starter reduction gear cover?
Old 02-11-2015, 11:36 AM   #3
Good catch, Mudflap. I agree that it's likely the starter.
Old 02-11-2015, 11:58 AM   #4
X3; that is the only possible explanation I can fathom.
Old 02-11-2015, 01:00 PM   #5
Assuming it is the starter gear there are 2 thrust washers, one to go on each side of the gear.
Old 02-12-2015, 07:04 PM   #6
thanks
I forgot to mention it was not the one circled but the one with the Ls on it and not the one that says lifan. But i believe your right thanks
