Old 02-02-2015, 01:38 PM   #1
crawdaddy34   crawdaddy34 is offline
110 ATV won't run
Hey guys, I sure hope someone can help me out here...
A few weeks ago, while we were out riding, Mini-Me's four wheeler started acting up. Anything above about ¼ throttle would make it bog real bad and if you didn’t back off the gas it would shut off. Seemed like it was starving for gas or air. No obvious fix on the trail so took it home figuring it was a fouled carb.
Took the carb off; not serviceable. Put it back on and the problem was gone. All I did was unbolt it, pull it out, cuss about the shaved screw heads, and put it back. Ran fine for a few days then did it again. Took carb off and put back on again (hell, it worked last time) and while I was at it I bought a good plug and replaced that. Didn’t fix it this time.
Ordered a new carb under waranty. Company took three weeks to send me the wrong part.
I ordered a new one myself which showed up Friday. Saturday morning I had him ride it pre-replacement to verify issue was still there; it was. Anything over ¼ gas it would bog and die.
Replaced carb (fyi – slightly larger – 20mm new vs. 19mm stock) and it was back up and running. Better then before, seemed a little quicker and sounded MUCH better.
For a few hours… Then the bog and stall came back. Below is everything I tried last night –
Took fuel line from tank straight to carb – bypassed filter/petcock – no change
Took crankcase line (that is hooked to the air filter with a check valve in-line) off case – no change
Took air filter completely off – no change
Gassed it until it started acting up and then started shutting down the choke (to much air?) – no change
Held the back end up (now it’s not “under load”) and revved it up – no change
Adjusted the idle up close (doing it by ear) to where it wanted to cut out when using the throttle – continued to idle fine; no bog. Blipped the throttle and it bogged down.
I’m going to go get a can of starter fluid to check for air leaks around intake, some carb cleaner to clean up the carb, and a new fuel filter to replace Chinese one. Don’t expect any of that to fix it, but ruling things out.
Also; this may not be related but….
The battery on this thing is a POS. When we pull it out in the morning it doesn’t have the juice to crank it, gotta “boost” it for ~5 min. before it will crank. Usually once boosted and we get it started it’s good the rest of the day. Well yesterday he shut it off and when he tried to start it again it wouldn’t bust off. I did a little investigating and discovered that if you hit the starter and give it some throttle it acts like the battery is dead (slow turnover, wont fire). But once you let off the gas, it spins over slow a time or two (clearing the pressure?) and then the revs start to pick up and it will start. Almost like it’s over pressure in the cylinder if you open the throttle…
Because of the above I’m thinking maybe an exhaust valve issue??? To tight, not letting pressure out fast enough maybe? Maybe that’s causing the bog when you give it gas??? I’m going to get a set of feeler gauges and check/adjust the valve clearance.
Again, don’t expect a magic fix but it’s something to look at. I know these things require periodic valve adjustment, but I can’t see it being out of whack at < 10 hours.
I was going to pull the plug, hook it up and ground it while I hit the starter to verify that I’m getting fire, but it starts and idles fine, so no sense in that. I’ll still pull to inspect (correct color, no oil, etc.) just for fun.
I don’t think it’s anything mechanical, symptoms/trouble shooting so far just don’t fit.
Which leaves electrical; the CDI boxes on these things are know issues, but 99% of the time they are good/no good. So why does it start/idle if that’s bad? I suppose it could be bad and only displaying once the revs come up, but that’s a LOOOOONG shot. Only $5 so if tonight’s tinkering doesn’t fix/isolate the issue I’ll probably get one just to say it’s been replaced.
Aside from the CDI there is a battery (for starting only), a magneto, a voltage regulator/rectifier, and a million electrical connections. I haven’t gone thru them all but I can’t believe it’s a bad connection or the magneto because of the repeatability of the problem. It doesn’t come and go on its own; it runs fine, then all of the sudden won’t come off idle without cutting out. Take the old carb off, put it back on; it’s fixed (for a while). Take the old carb off, put it back on, it’s not fixed. Take the old carb off, put a new one on; it’s fixed (for a while).
Which leads me back to mechanical, but I’ve checked (almost) all of that.
Small chance it’s the valve adjustment, but I’ll verify that tonight. If it jumped timing it would be jacked from idle so I don’t think that’s it, plus it showed up, went away, came back, etc... If timing was off it wouldn’t run at all, or would run like crap from idle on; correct?
Oh, also – When I started looking at it last night (right after it started acting up) the air intake (short, curved aluminum “tube” going from the carb to the head) was hot. REALLY HOT. Maybe he over heated it, but before I put the new carb on he test rode it cold and it still did it.
Short of a .40 thru the engine block, anything else you can think of? I’m running short on ideas after the above…
Old 02-02-2015, 02:24 PM   #2
Welcome! Thanks for joining us.
Don't expect that the valves were ever set correctly from the factory. My money is on at least part of the trouble being caused by the valve clearance.
If you open the throttle while cranking, you're introducing more air that the engine must compress. They don't like that. A properly tuned motor like this should start with no throttle.
A spare CDI is terrific for troubleshooting.
A good battery is very important. A new one is money well spent.
Your logic is right on track. You're not far from the solution.
Old 02-02-2015, 02:48 PM   #3
Thanks for having me!
My only hesitation with blaming the valves it that I didn't do anything to them the last two times this problem just "went away". Would they fix themselves and then get out of whack again?
Old 02-02-2015, 06:45 PM   #4
Not fix themselves, but run marginally on and off.
My Pastor's scooter wouldn't start after her dropped it, and it drove me crazy. I went through every system (some twice), trying to figure out what would cause it to not run after a minor crash.
It coincidentally picked that moment to present the valves as the problem. The motor ran fine before that, and the adjusters were not loose. Weird. You can read about it here if you like: http://www.chinariders.net/showthread.php?t=9421
