Old 01-01-2015, 01:08 PM   #1
Mudflap   Mudflap is offline
carrying capacity of Zongshen 200
I was comparing the owners manual to the manufacturers plates on the bike and noticed the maximum GVW as listed on the plate is 901 lb. That seems like a lot of weight for a small bike, more than my touring bike! Could this be for carrying a half dozen pigs or a family of five? Or is it a mistake?
Old 01-01-2015, 02:20 PM   #2
katoranger's Avatar
You must have the half ton.
Old 01-01-2015, 04:30 PM   #3
Old 01-01-2015, 04:41 PM   #4
If you become a postman you can haul the mail with it.
Old 01-14-2015, 09:56 AM   #5
mrpete   mrpete is offline
He's really carrying a lot of weight on that 200cc. Hopefully, he won't hit any BuMpY side streets!
Old 01-14-2015, 07:39 PM   #6
bogieboy's Avatar
the GVWR is factoring in the weight of the bike as well.......even so, that leaves around 6-650# of capacity....
Old 01-14-2015, 07:51 PM   #7
Here's my Lifan hauling a generator, and a heavy battery charger in the action packer box, along with groceries and other junk. That's one heavy duty rack they put on the Lifan. Rode several miles down the 65 mph freeway on the way back from Harbor Freight in Yuma.
Old 01-14-2015, 07:56 PM   #8
katoranger's Avatar
I had about 100lbs of trailer brake parts strapped to the rack of my lifan. Made the front wheel pretty light, but the rack didn't move.
The Chinese know how to build a strong rack.
Old 01-14-2015, 08:32 PM   #9
Indeed, the Chinese build these bikes tough, with strong subframes. That's why I am confident the Zongshen RX3 can carry the loads for adventure touring with aplomb.
Old 01-20-2015, 09:32 AM   #10
I've been looking around to see if I could find what frame this particular Zongshen is a copy of and finally found it, it's a Beta Alp 200. Frame, forks, triple clamp, handlebars, speedo, swing arm, seat, turn signals, rear rack, foot pegs, and more. The Beta uses a Suzuki DR engine where the Roketa (Zongshen) uses a Honda CG clone.
The bikes are a cross between an enduro and a trials bike and have reversible foot pegs which allow you to move them about 6" to the rear for stand up trials riding. Dry weight is is only 223 lbs on the Beta and is listed as 222 lb in the Zongshen owners manual.
Old 01-20-2015, 11:02 AM   #11
Interesting!
Are you saying that the frame of the typical Roketa bike (with a CG200) is a copy of a Beta? My Roketa is definitely a copy of a Honda XR200 (early '80's twin shock version, modified for monoshock).
Which bike are you referring to? Do you have comparison pics?
Old 01-20-2015, 11:10 AM   #12
Ok, I just went back to your thread about your Roketa, and I see what you mean. Your comments about the low gearing make a lot more sense now.
Did you ever get it registered for the street?
Old 01-20-2015, 03:35 PM   #13
Yes it's now registered in Oregon. I have the title, plate, tags, etc..
Roketa being just an importer puts their name on lots of different bikes. This particular one is the only copy of a Beta Alp I've seen, and I've never seen a real Alp. If you look close at the frame, forks, swing arm, rack, and most other parts, it's obvious. The aluminum rims are nicer on the Alp.
Old 01-20-2015, 05:50 PM   #14
Indeed, I see many similarities. Does the Beta Alp have a kick stand on the right side?
Old 01-21-2015, 12:08 AM   #15
Can you do the footpeg, seat and tank cover trick, just like an ALP?
