Old 10-17-2014, 04:17 AM   #1
Justnflrs   Justnflrs is offline
Justnflrs's Avatar
Modifications to my Viva thus far
Angel Halo Headlight, Honda XR200 FMF Powercore 4 Spark Arrestor, Yamaha XT225 4.1 gallon fuel tank
Old 10-17-2014, 12:57 PM   #2
I really like the Yamaha, 4.1-gallon, XT225 fuel tank I installed on my Zong. I'm impressed you got that fuel tank mounted on your Viva.
Old 10-17-2014, 10:09 PM   #3
I know, I know, the grass is greener, blah, blah--but if I could get one of those tanks on my TMEC, I would only need to fill up once a week....
Old 10-18-2014, 02:14 PM   #4
So cool! Was the XT225 tank a direct fit? How did you figure that out?
Old 10-18-2014, 02:15 PM   #5
I recommend that you remove that goofy ABS device on the front brake. It's the gold thing at the end of the brake hose.
Old 10-18-2014, 04:26 PM   #6
Justnflrs's Avatar
Thanks spud! Your thread on installing it onto your Zong helped a lot!
Old 10-18-2014, 04:31 PM   #7
Justnflrs's Avatar
Thanks w&g! Pretty much a direct fit when I mounted 2 hockey pucks on each side of the frame where the tank sits. I pretty much followed spuds instructions to his zong and instructions from a tw forum
Old 10-18-2014, 08:49 PM   #8
You're welcome. I'm glad I was of help; thanks for letting me know.
Old 10-19-2014, 02:48 AM   #9
Justnflrs's Avatar
Hehe Target brand saddle bag haha
Just bolted it on random extra brackets
Old 10-19-2014, 02:53 AM   #10
Justnflrs's Avatar
Will it affect the way I ride/brake?
Old 10-19-2014, 03:49 AM   #11
zingshoen   zingshoen is offline
zingshoen's Avatar
that s a groovy looking ride. do you plan to add a white polisport super motard front fender?
also: where s you license plate mounted? i can t tell from the second pic.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 10-19-2014, 04:16 AM   #12
Justnflrs's Avatar
Thanks zingshoen!
Probably not, I like it black and "Frankensteiny" I made it from the original fender. Just cut it and bolted the front half on top to shorten it
Bolted it with a small 90 degree angle bracket onto the toolbox threads on the frame. I hated how my tool box emulated an exhaust. It looked tacky. And I didn't like how the original license plate holder extended out super far. Replaced it with a UFO fender that had a brake light and just drilled signals on the sides.
Old 10-19-2014, 12:20 PM   #13
Not likely. If you remove it, change the brake fluid and bleed the air out properly, you'll have a predictable front brake. I don't trust the ABS device, and neither do several of the members here.
Old 10-19-2014, 12:21 PM   #14
You got lucky, since your bike is totally different from Spud's. It's so nice how your seat follows the contour aof that tank! I might try the same thing on one of my bikes.
Old 10-20-2014, 05:57 PM   #15
zingshoen's Avatar
Ok, thanks i can see it now!
